What type of CD-ROM should I use for ASUS P5QL-E Board
I currently using an used ATAPI CD Rom and I wish to set-up on a new Asus P5QL-E Board. The cable doesn't match.
What is your recommendation on the type of cd rom I should use.
  • Kevin Nelson May 11, 2010
    what type of cable are you using? There are sata connectors as well as ide connectors on the motherboard.
  • Justin Bellomy May 11, 2010
    Your ATAPI cdrom is using an standard IDE. The P5QL-E motherboard has an IDE port on it. What about the cable does not match?
  • 1,901 Answers
As the others have said, your MB has an 40-pin IDE connector just to the right of the SATA connectors. It is at a 90 degree angle to the SATA connectors and parallel to the RAM slots.
It is shown on Page 2-26 of the manual. (Available at )
Remember there is a pin missing so that the cable cannot be inserted backwards.
Posted on Dec 10, 2008
Need jumper settings to make ASUS CD-ROM-S480/ah the master CD -ROM
no jumper setting needed it is based on cd rom connectivity wire.......use first block to make it master
Nov 14, 2010 | ASUS Computers & Internet
iat the time of boot a message as follows is displayed
"boot block compatible version .005"
bad bios cheksum. starting bios recovery
checking for floppy. floppy not found
checking for cd rom. cd rom not found"
.. using asus motherboard
Sep 06, 2010 | ASUS A8V-VM Motherboard
I am new to building pc's and I've just bought a asus p5ql motherboard, 4gb ram, intel processor and a hd. I have it all together. Green light on board, fans spin, etc. I get the Asus start up screen and...
Just follow these simple steps:
1. Make sure you have all the discs included in your package.
2. After you power-up, strike del key to go to bios/system.
3. In boot selection, select DVD/CD ROM to boot first, HDD second and other if you wish..
4. Press ctrl+alt+delete to restart.
5. After pressing the tree (3), insert your CD/DVD installer to the drive..
6. Follow the instruction...
Good luck and have a nice day!
Feb 16, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Bios Utility Setup
Tell it(The BIOS set up screen) to load default settings. Start up CD driver first. Then  Save and exit. Now install Xp disk and turn computer back on. After windows loads . Run the install disk that came with *********** board.  If I missed something or is doesn't work exactly as I stated , write back and I wil assist you farther.
BIOS and Sony CD-RW CRX300E
Your Sony CD-RW is an ATAPI CD-ROM for the purpose of your BIOS. Without you specifying the motherboard brand and model, it is hard to tell you what your issue could be.
Nearly all PC motherboards made after 1995 will allow you to boot from the CD. Enter the BIOS setup screen by pressing, during POST, <DEL> or <CTR>-S (Gateway), <F1> or <F2> and look for boot sequence. Some MB's have a boot sequence key you can press to select the boot device for that boot instance only.
If you are trying to say that you have an ATAPI CD-ROM and the Sony CD-RW, then check your master/slave/cable select jumper settings on the device. Each IDE channel can have at most one master and one slave.
Jul 13, 2008 | ASUS Computers & Internet
Cd rom message "no emulation" when booting the windows xp installer
when i install my windows xp professional i get a message prompting BOOT TO ATAPI CD-ROM: "NO EMULATION".... how can i fix this?Pls help me on this
Jun 07, 2008 | ASUS P4SP-MX Motherboard
BIOS 1004 cpu not support
I got it :-)
Damn Asus , it was a hard session ;-)
1. Make an ISO from your original Asus CD denn insert (with isobuster or something) the Bios Firmware 1004 in the main Dir name the file M2N-MX.ROM
2.Burn a Second disc with the 0804 Bios ROM also rename the 0804 Rom to M2N-MX.ROM
3. Go to EZ FLASH with ALT + F2 and then insert the 1004 CD wait till Erasing is ready Then Turn OFF your PC :-) so you crashed the bios thats what you need to run the embeded CrashFRee Tool
4 After you turn your PC on insert the 0804 CD then it flashes the this Rom and we are Happy :-)
mfg Eddi Hope this helps someone
Apr 16, 2008 | ASUS M2N-MX Motherboard
I can't use HDD sata on mainboard ASUS P5RD1-VM
Things need to be turned on in your bios patrohi. This is why windows didn't boot to the SATA. You need to use your manual & make sure the, Serial ATA Controller is [Enabled]
Within the Advanved menue under SouthBridge Configuration.
At the Main menue the SATA drive should be listed.
Boot settings need to change as well. At Boot Settings Configurations. Make sure your SATA drive is listed.
Boot order should list like, Floppy 1st, CDROM 2nd, SATA 3rd. The SATA will not list as a SATA but the model number of the SATA drive. Once all these settings are set save & exit. Your drive should show up for work & the windows CD should load.
Feb 20, 2008 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
425 people viewed this question
David Payne
David Payne
