Question about PC Chips M810DLU (M810DLUV75C) Motherboard
Need the motherboard manual for a m810d ver 7.5 motherboard so i
A friendof mine brought me a pc that hasthe power switch ,reset switch and hdd led. cables disconected. i have tried to find a manual but its being imposible. please can you help me. if you can i need a manual or pictures where the cable go in the panel.thanks
  • 395 Answers
Ms-6541 ver 2.1 mobo pin connector
Hello this should be the homepage:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=97106&prodTypeId=12454&prodSeriesId=96284&swLang=13&taskId=135&swEnvOID=1093
The front panel looks like this:
d450e023-b94a-4bba-87c8-871096a37704.gifF_P1 PinOut
17 15 13 11 9 7 5 3 1
18 16 null 12 10 8 6 4 2
SHORT:
HDD led op 1/3
Power led op 2/4
Power Sw op 6/8
Reset Sw op 5/7
Here is also the manual:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&locale=en_US&docIndexId=179911&taskId=101&prodTypeId=12454&prodSeriesId=316609
The usb connector looks like this:
e3c82873-b0a1-49b3-91f4-548ca5550428.jpgIts basicly just to insert the black connector in it.
Best of luck
Jul 16, 2013 | Computers & Internet
Ms-6368 ver:2.1 manual
Cut and paste this link...select the DOWNLOAD tab, click on MANUAL.
Choose the 2.0 version of the manual. It supports 2.X versions of the motherboard. Page 2-14 has the infomration you need.
http://www.msi.com/product/mb/MS-6368.html#/?div=Manual
nqjkujcuh79+vxr3fpuimnn5x9mjblkzhq6xzkfbgdogvrhqyfssmj1awualahyhaaagmkbxweaumua4waaqgxacqaa1dlgoaaaahlwhaaatqw4dgcawgycbwbalqooawcglghhaqbqy4djaacozcbxaadumua4aabqgxacaac1ddgoaibabhwhaeata44dakcw+f8ulsndi3vv6qaaaabjru5erkjggg==
Jan 17, 2012 | MSI Computers & Internet
Zapojenie power switch,hdd led,reset switch power led
i945lm4 ver:2.2 of where do I plug the power led, hdd,reset.
Feb 18, 2011 | PC Chips M952 V1.3b Motherboard
Lookig for a manual for an fic au13 motherboard
Front Panel Block Cable Connections
f_Panel
1 3 5 7 9
2 4 6 8
1] HDD-LED (+)
2] Dual Power-LED* (+)
3] HDD-LED (+)
4] Dual Power-LED* (-)
5] Reset Switch
6] Power Switch
7] Reset Switch
8] Power Switch
9] Dual Power-LED* (**)
* Single Color Power-LED 2 or 3 pins:
1 2 3
1]Power-LED (+)
2] GND
3] GND
** Dual Power-LED:
if useing dual power LED,
Green: pin2
Yellow: pin4
otherwise, Pin2 is positive (+) Pin4 is negative (-
For future Reference you can download your manual directly from the manufacturer's website HERE
Or directly from HERE
May 30, 2009 | FIC AU13 Chameleon Motherboard
Hi i have a problem with panel1 on M848A v5.0 motherboard i cnt seem to work out how to connect the case properly it looks like this ()()()() ()()()()() i have the power switch, reset switch, hdd led and...
OK, this is for all the idiots who reply and offer NOTHING. You need more info, model and ver? HE ALREADY GAVE ALL THAT INFO.
Type "M848A v5" in google and you will see it is a PCChips mobo AND the manual is here:
http://download.ecsusa.com/dlfilepcc/manual/848Av50.pdf
BUT the manual DOES NOT HAVE THE PIN-OUT, so the manual is worthless...
Here is the pin-out:
(2)(4)(6)(8)
(1)(3)(5)(7)(9)
...and thanks to guntotenmadm
Aug 28, 2009 - The pin layout on the MB are color coded. There is green, orange, pink, and blue. I'll start with the green pins 2 and 4 these are for the power led wires, bottom pin #2 is the + pin (your green wire). Pin #4 is - (your white wire). Now the orange pins, pins 1 and 3 these are for the HDD led. The bottom pin #1 is the HDD + pin (your red wire). Pin #3 is the HDD - (your white wire). Now the pink pins, 6 and 8 these are for the power switch. Pin #6 is the + pin (your orange wire). Pin #8 is the - pin (your white wire). Now the blue pins, 5 and 7 these are for the reset switch. Pin #5 is the - (your white wire). Pin #7 is the + (your blue wire)."""
May 18, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
I tried several different cards but no luck. Cards work ok on other computers.
5V Stand-By Indicator LED
The power supply will always supply a 5V standby voltage to your
motherboard so that it can power on via for example Wake On Lan
technology. This LED shows that your power supply is supplying
this standby voltage to your motherboard.n :D
You may need to replace your power supply, if the LED is flashing, it's not supplying the power the motherboard needs.
[JP-25]
1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18
1] Power Led (+)
2] --
3] Power Led (-)
4] --
5] --
6] Speaker (+)
7] --
8] --
9] Speaker (-)
10] Reset switch
11] Reset switch
12] N/A
13] Power Switch
14] Power Switch
15] ACPI Led (+)
16] ACPI Led (-)
17] HDD Led (+)
18] HDD Led (-)
For future reference you can download your motherboard manual here:
(PDF) Soyo K7VKP2
May 09, 2009 | Computers & Internet
I need to conect the switch power cables to a m810d ver 7.5 motherboard and i need the manual to this mother board so i can conect the hdd led, reset swtch etc.
You could try looking on the line to see if there are any available online manuals or if theres an available number call the manufacturer. I just went to the manufacturers website pcchips.com and found manuals to a v7.1. You might be able to use one of those manuals as a referance point.
Dec 10, 2008 | PC Chips M810DLU (M810DLUV75C) Motherboard
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
Where are the conectors HHD Led y power led
it should be in "one group" with power switch,reset switch connector. usually there will be a label on the motherboard ... use magnifying glass if you can't see the small print.
Oct 30, 2008 | ASUS Computers & Internet
PC Chips M810DLU (M810DLUV75C) Motherboard Logo
3,029 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
