Question about Bosch Nexxt WTMC 3300 Electric Dryer
Dryer not drying
Bosch WTMC 3300
Where is the reset button and how do I get to it?
  • 1 more comment
  • jasontraci20 Dec 10, 2008
    Dryer is still not heating. Thank you for the suggestion.
  • crysfons Feb 12, 2009
    I just got the bosch 500 series, whenever I check the inside its never warm or hot is it supposed to be?
  • Anonymous Apr 10, 2009
    no heat, drum turns
All these experts, but no one can tell where reset button is, i finally found it, remove back cover, about 20 small screws, look on right side toward bottom, of dryer, 2 screws hold sensor with reset button, make sure dryer is unpluged, remove sensor clean lint from around it put screws back in, works fine, ive been looking for days for an expert to be able to tell where reset is, im no expert, i am a car salesman, but i found reset
Posted on Oct 18, 2009
  • nancy Aug 13, 2013
    well I still can't find it. Why would a company make a reset bottom so hard to find?? There's nothing on the bottom right with 2 screws, help??
  • 750 Answers
Hello welcome
You asked,Bosch WTMC 3300 Where is the reset button and how do I get to it?
Try going to the breaker box and powering the unit off for 5 minutes. This will reset the system and remove any electronic glitches.
Thank you Huum
Please remember to leave a rating before you go!
Posted on Dec 10, 2008
How do you reset the Bosch 500 series dryer?
One has to remove the back panel (need Torx bit). Down by the exhaust vent, there is a small red button (see detailed drawing) and push it to reset. It is annoying but will save a lot of money on a service call.
May 26, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
What is recommended load size for Bosch Nexxt dryer
The Bosch Company is probably known best for its high-end dishwashers, but the company also produces other home appliances including refrigerators, stoves, washers and dryers. Bosch dryers carry the Energy Star rating. A Bosch dryer has a structured drum that provides more thorough drying and condensation drying for faster cycle completion. If mechanical problems occur with the dryer and troubleshooting efforts fail, performing a reset may return the dryer to normal functioning.
Instructions
1Unplug the Bosch dryer from the power supply and then reconnect to the power supply.
2Replace the local fuse or reset the circuit breaker if a fuse or circuit breaker has tripped.
3Place items to be dried into the dryer and select a program. Close the door firmly.
4Press "Start/Pause."
5Press "Stop/Cancel" if the above steps do not resolve the problem.
6Pull the dryer out from the wall and use a standard screwdriver to remove the central metal plate on the back of the dryer.
7Locate the small red reset button above the heating element and press and hold the button for a few seconds. Release the button.
8Place the back access panel back on the driver and move the dryer back against the wall. Repeat steps 3 and 4. If the problem continues, press "Stop/Cancel," turn off power to the dryer and contact an authorized service technician for assistance.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
When the dryer is running it sometimes makes a screeching sound momentarily on and off during the dryer cycle. Some cycles it does not make the sound at all. Is something going bad? It doesn't seem to...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
May 02, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
It is not drying, what could be causing this?
check breaker box if this is not the case then the heatting element went bad
Feb 11, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
My dryer will not heat up. I have to hit the reset button and it will dry one to two loads then need to be reset again.
There is a good possibility that you have a clogged or kinked dryer vent. Check for kinks between the unit and the wall. for clogs, the most common spot is right at the vent opening outside. Alot of times there is a screen to keep animals/birds out, that clogs with lint and causes the dryer to not dry well and/or have problems like you are describing. Hope this helps.
Dec 06, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch dishwasher washes dishes but does dry completely
Heating element is probably not working. Open during dry cycle and feel if it's hot inside.
Nov 06, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer will heat for awhile and then shut off, requiring resetting the reset button.
Must be a restriction of air flow due to having too many clothes in the machine,blocked vent, or lint buildup in the machine.
Oct 21, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer
I have a Bosch Nexxt WTMC 3300 electric dryer. The dryer doesn't heat up. This is the second time this has happened over a one year period. The first time it happened, the technician reset the thermal cutoff, but said he saw no reason why it should have tripped. Can you tell me how to reset the thermal cutoff or offer another solution?
Apr 25, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
2,578 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
