Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Convergence scrambled..how do i use remote to get to service mode
I need to do a "course convergence adjustment" using the remote control to get to the service mode to fix. how do i use the remote control to do so, and is it possible?
  • 4 more comments
  • alvintay88 Dec 17, 2008
    i have the same problem. please help?
    The image is shifted to the right. how do I get back to normal full screen image? Please help?
  • MARTIAL9 Jan 07, 2009
    I would like to reset my convergence to manufacturer set up. Do you know how to access convergence procedure from system menu? martial9@msn.com
    I appreciate any help I can get.
  • boots_c Jan 13, 2009
    HELLO AND THANK YOU IN ADVANCE. I HAVE A PRECISION TV MODEL PTV-2148, THAT I NEED TO ACCESS THE SERVICE MODE.THE PICTURE HAS SHIFTED TO THE RIGHT SO I NEDD TO REPROGRAM THE H-MODE.
    My e-mail address is davidbootscorbin@hotmail.com
  • Anonymous Mar 08, 2009
    can not see bottom of picture vertical need adjusting.Need to get into service mode.
  • Anonymous May 13, 2009
    Electech1 here
    sorry but I have been overworked , so I will leave this link http://www.eserviceinfo.com/downloadsm/3...
    for all of you that want it , it is a service manual that will assist you in your repaiir or adjustments
    this is a "22 part" download that will need to be save to a file in your computer then extracted with " winzip " and " adobe " to read it
    electech1
  • 905 Answers
This is going to take you some work ,do you have a hotmail address that I could send you the procedure?
Posted on Dec 10, 2008
What is the procedure to do color convergence on a hitachi 50vs69a
Almost all you can either get into the mode by use of the remote or remove front speaker grill and inspection plate behind it, there is a tiny blue push switch which will put you in the convergence adjustment mode, then various buttons on the remote do different things and save the adjustments.
Of course if convergence will not adjust you have a bad chip and this model uses two so both get replaced in that case.
Aug 27, 2012 | Hitachi 50VS69 50" Projection HDTV
Service code needed to complete convergence adjustments
I have the service convergence code: mute-1-8-3 (make sure your tv is on and set to antenna. if it doesn't work press S. Mode and make sure is says standard then re-enter code.
So, I have the code but I need the convergence chips. Where did you get the convergence chips?
Jan 26, 2009 | Samsung HCM653W 65" Rear Projection...
Convergence problem
reset your tv with defaults settings.f chip and resstor blown then it need change.
Jan 06, 2009 | Philips 55PP9401 55" Rear Projection...
Convergence is scrambled due to power outage. how do i use remote control to get into service mode to do a "course convergence adjustment" ?
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 10, 2008 | Panasonic PT-47WX53 47" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Rear Projection Samsung w/ convergence out
I believe it is mute-1-8-3 to enter the service mode, HOWEVER, I have also read that until the convergence problem is repaired, i.e. - depending on the configuration, either 2 individual IC's located on the lower board with 'playing card' size heat sinks or a simple replacmenet convergence board, adjusting the convergence through the service mode is comparable to "ripping the transmission out of your car to fix a flat tire". I myself have not gone into the service mode since I am still waiting for the replacement IC's - I get to do a component level repair.
May 05, 2008 | Samsung PCL545R 54" Rear Projection...
Hitachi 43FDXO1B Convergence?
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACH REMOTE CONTROL. NONE ELSE WILL DO.
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Jan 13, 2008 | Hitachi 43FDX01B TV
Convergence
Replaced convergance power packs (2) stk392-110 check all 2watt resistor the packs, to enter the convergance alinment mode on the set. Using the remote control press and release the sleep timer button when sleep timer displays timer equals zero immediately press the display and V. status buttons at the same time.  If done quickly enough the service menu will appear once entered the careful not to does disturb or change any other settings press the number seven to enter the convergence alignment mode a full crosshair pattern will appear in this alignment mode you can adjust the blue and the red to line them on the green using the select and the number pad you can move to the next crosshair to align the boot to the green and then the red to the green when done pressing the muting button on the remote control will save your changes will take a little while to figure this out as you work with.  If you make an unwanted error pressing exit without hitting the muting button will restore your convergence to its previous  setting.  If you're green is off after entering the service mode press the number six on your remote control in this setting will be able to adjust the green only once that is done us the muting button.  Then enter button seven if need be to adjust the blue and the red.  Remember no changes have been stored until the muting button is pushed open this helps.
Oct 14, 2007 | JVC AV-48WP30 48" Rear Projection...
Convergence
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Aug 10, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
230 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
