Question about Mitsubishi WT-42315 42" TV
Left side of screen turns red
What causes this? also, how do I fix it myself?
  • Anonymous Jan 04, 2009
    I had a problem like this. The red separated from the blue on the left side, slightly on the right, and couldn't be fixed using the automatic or manual convergence methods. Unfortunately I had to call a tv repair shop. They had to replace the red color controller microcircuit. It cost about $350, but I had only spent $300 buying this tv from a friend so I deemed it worth the cost. The repair man said this part hardly ever fails so they didn't even stock the part. I guess we are the lucky ones with defective parts.
  • 3 Answers
Posted on Jan 04, 2009
  • 60 Answers
First check if in that area you have some loudspeaker if so remove it from that location and put far away from your television and then turn off your tv , i mean unplug supply cable for 15 min and then turn on to see if that problem was fixed if that dont work go to one authorized service
Posted on Dec 10, 2008
Panasonic TC-L58E60..Picture problems Can anyone help me solve what is wrong? I can fix it myself if i knew what was causing this issue thanks
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 11, 2016 | Televison & Video
What will cause a wavy blue lines running left to right from the top down
That is knon as a convergence failure. Its real common an a failry easy DIY fix. You can read more about how to fix it here in this video and on the fixya tips page below.
07e70208-1f08-4826-857e-065c46e4dbb8.pngFixya Tip Page
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 15, 2013 | Philips Televison & Video
Bush IDLCD26TV16HD Left side of screen red causing distortion
Check its degaussing posistor at the power supply regulator section.
Apr 02, 2012 | Bush Televison & Video
Can not line up the red digital array crosses along the left side of the tv screen
Same thing happened with mine, tried to fix it myself with no avail, called a repairman, $300 to fix.
May 09, 2010 | Hitachi FDX Series 43FDX10B 43" Rear...
Red bar at left of screen will not dissapear
Good Day; Carlo;
There is an adjustment. Try the Convergence Adjustment, if no fix, the TV's circuits need repair and you should an Authorized Service Center, GET estimate first. Good Luck, big IRISH.
Jun 29, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Thin Red Line on LCD TV
I had a similar problem with my LCD screen TV, and to my dismay, my warranty just ran out. A thin red line began to appear on the right side of the screen, and since many online and expert sources pretty much say replace the expensive LCD screen or get a professional to fix it (in which I suspect to be a business plot to get people to go to pricey experts), I decided to look for other possible alternatives.
Here is some tips/solutions I was given (and it worked! at least for me):
1) Turn off the LCD and unplug the power source and let it rest for 5-10 minutes. Turn it back on and see if it disappears or improve. (This is the one I used.)
2) While turned off, try jiggling gently all chords connected to the TV (cables, power chords, etc.); you could even try unplugging and replugging the chords/cables. Turn the TV back on and see if the red line disappeared or improve. (This is the one I heard worked for others.)
If the above doesn't work then I'm afraid you do have a bad panel on your screen and will need to call in the experts or get a new TV. I hope this will help. Best Wishes.
Apr 01, 2008 | Televison & Video
Permanent Red Line Down the left side of the screen
This can't be repaired, the LCD panel is a sealed unit. if you can't live with it then you need a new monitor
Feb 20, 2008 | HP Pavilion F1703 17" LCD Monitor
Gray line on left side of screen
I spoke with Samsung - they said this is a minor and easy to fix problem caused by a "blocked or collapsed channel" - whatever that is. They also recommended that if I have any warantee coverage (I do) that I not attempt this repair myself and that a technician be called in. That's my plan. I hope this helps.
Dec 12, 2007 | Samsung DLP HL-P5663W 56" TV
Blue Halo, Tried to adjust on Projection TV
The convergence issue you have will not adjust out....repair
of the convergence circuit will be necessary....then adjust...T.
Dec 01, 2006 | GE 46GW947 46" Rear Projection Television
Mitsubishi WT-42315 42" TV Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
