Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox Bluray Player with the HDMI Cable will not produce sound
All settings appear to be correct but unable to hear sound from the Magnavox Bluray player through the TV Speakers or the Sourrond Sound.
  • 2 more comments
  • mail4steve Dec 26, 2008
    all dvd's work great, but got my first blu-ray movie and no sound...please help
    I also have a HDMI cable
  • kwolff4545 Jan 02, 2009
    Same problem. Everything works with a regular dvd, but as soon as I try a blu ray...no sound. I also have it hooked up via an HDMI cable.
  • swinnie13 Jan 17, 2009
    Same problem. Blu ray discs will not produce sound, but do produce video. Also checked to be sure the HDMI cable works. Please help.
  • Anonymous Apr 22, 2009
    same problem as the last person picture but no sound.
No sound on my blue ray player
Posted on Feb 20, 2011
What are the best settings for the DMP-BDT330 Panasonic Bluray Player
Hello Myles, we recommend you connect the player with a HDMI cable and then set the player's output to 1080p.
Apr 27, 2014 | Panasonic Televison & Video
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
CAN I USE HDMI CABLE TO PLAY MOVIE THROUGH DAV-DZ270 TO A LCD TV ?
Yes. This is what you should do. Connect the Bluray players HDMI cable directly to your TV, then use an optical cable (usually around $20-40) to go from the Bluray player to the surround system. You will then need to enter the menu of the Bluray player and set up the Audio to be run through the Optical output instead of the HDMI. Problem solved!
Jan 21, 2011 | Sony DAV-DZ100 System
No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
Jul 17, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Hooked up BluRay with HDMI cable and I can hear sound but no picture.
problem with the cable! try using the same cable HDMI cable for another system i.e dvd player, something that has an HDMI in-port
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Oct 09, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Jan 12, 2009 | Yamaha RX-V661 Receiver
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
RXV 1500, I am unable to get 5.1 audio
Just got off the phone with Yamaha customer support, who were very helpful.  The display on the amp, in the lower right hand corner, displays the source input, not the output.  So, for example, you can be watching cable tv, and the cable tv is sending a 2-channel stereo signal to your receiver.  Your amp shows only L and R.  But since it has a processing system, depending on the processing program you have chosen it will probably distribute that sound to all five speakers.  You will be confused, because you hear sound from all speakers but you only see L and R lit up.  You will believe that you are not getting 5.1 sound.  And you will be correct: you aren't, because the source is not sending you a five-channel signal.  That's where I got panicked.  So the Yamaha representative said, insert a DVD that you absolutely know contains a Dolby Digital audio.  I inserted Shaolin Soccer DVD, went straight to a scene in the middle, and bingo!  The center and surround right and left speaker lights lit up!  So there is the 5.1 surround sound.  It will light up when it detects that kind of sound from the source.  Otherwise it will probably give you a sort of "fake" 5-channel sound that it creates from a 2-channel source.
Now the question becomes, are your connections getting the 5-channel sound to the amp correctly?  I just confirmed that my DVD, connected with a Coaxial cable to the Yamaha, does get 5.1 surround sound, if the sound is encoded in the DVD.  I have not tested this yet with video games or Blu-Rays; I will post again if and when I confirm that this works on a PS3.
Apr 01, 2008 | Yamaha RX-V1500 Receiver
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
877 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
