Question about Acer Aspire™ T180 PC Desktop
Acer problem every time i booth up my ACER pc i encountered this problem cmos bad battery,eventhough i replaced it already,i reset also the bios but the same problem i occured.how can i fix this problem? do i need to replaced my motherboard? is there any solutions before i replaced my board.
    Problem Solver:
  • 19 Answers
Ensure the new battery is the correct voltage and inserted properly (+ side is usually down). Check the manual for a jumper on the board used to clear the CMOS. With the pc unplugged from A/C power (the wall socket), short the jumper to clear the CMOS. You can put a jumper on for about 60 seconds, or hold a conductive material (the tips of most screwdrivers are ideal) across the two pins, again for about 1 minute. Be very careful not to touch or scratch the motherboard or any of the metal traces in it if you choose to use a screwdriver or other tool than a jumper. Jumpers can be easily moved by pushing a toothpick firmly into the hole in the center, then lifting straight up. When replacing, holding the toothpick, push the jumper into place, then twist the toothpick gently while pulling up to remove the toothpick without removing the jumper. A jumper is a small piece of plastic with a wire inside that connects (usually) two pins together. After clearing the CMOS, you will need to put the jumper back where you got it since you'll likely have to pull one off of the board, short the CMOS, then replace the jumper to it's original location -
*DO NOT FORGET WHERE AND HOW IT WENT ORIGINALLY*
Posted on Dec 16, 2008
Cmos settings for acer aspire m5641
to reset the cmos you only need to take the small round battery off the board for a few minutes. if your laptop is not keeping time then you need a new battery on the board. ( you will find you cant get on websites when your laptop has the wrong time on as its a security risk ) to enter the bios ( which i would not if i didnt know what i was doing ) turn off laptop/press power button to turn it on/keep pressing F2 while its booting up ..but be careful in there
May 24, 2015 | Acer Computers & Internet
Waar kan ik in mijn acer et1840 e machine computer de cmos batterij vinden
The CMOS battery is the small silver round battery on the motherboard. Be warned though, this will reset all of the time, date, and optimized settings in the BIOS. You will most likely need to reset all of that information.
Jan 27, 2015 | Acer Computers & Internet
Reset bios on acer aspire e380
You can reset BIOS setting by CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battery, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will clear the BIOS setting. Now, fix the CMOS battery & restart the computer. This will take care of the issue.
If the computer still does not boot, then it needs repair.
Thanks and regards,
Jitha
Dec 16, 2011 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
I have an acer aspire ast180-340b, I upgraded the cpu from Sempron to AMD Athlon 64 x2 3800+ but the computer keep saying I need to clear cmos. How do I clear cmos on this computer ?
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya Van Pham.
I have published a guide that deals with this very topic, it is entitled How do I reset my BIOS/CMOS to defaults?
You also may want to see the following guide entitled, How to Remove the Side Panels of My Computer Chassis!!!
Basically you will need to remove the CMOS battery found on the mainboard for a few seconds and then reinsert it again.
Take care!
Nov 01, 2011 | Acer Aspire (AST180-US340B) PC Desktop
How do you get the CMOS back on the Acer Aspire M1640
If you can enter the BIOS, by pushing either F2 or the Delete key after starting up the computer and seeing the first splash screen, you can reset the BIOS to factory settings. If you cannot enter the bios, in order to reset the CMOS, you must open the tower, look for the small CMOS battery (small watch style battery) and look for a set up 3 pins near the battery. There will be a jumper on on two of the pins. If you remove the watch battery and move the jumper over to the other two pins, replace the battery. Then remove the battery again and place the jumper back in the original location and replace the battery.
This process will reset the CMOS. You must also be sure to unplug the power cord from the tower before starting this process. Be sure the watch battery is not dead or the settings will not hold. So, if you're not sure, replace the watch battery.
If you found this information helpful, please remember to leave positive feedback.
Brian
Feb 05, 2011 | Acer Aspire M1640 Refurbished Intel...
Acer motherboard a springvale-6A79AFK8C-00 will not hold date &time in bios battery ok
Have you checked to make sure that the cmos jumper has not been left to the reset position?
You said the battery is good and the next step would be to make sure the jumper that clears the cmos is in the correct position and is set properly to prevent cmos from losing the settings.
DARK
Jun 14, 2009 | Acer Computers & Internet
BIOS password locked
Try to reset the CMOS using CMOS jumper reset. Look this in its manual how to do it.
Or take out the CMOS battery out of its socket then place it back again this should clear CMOS and restore to its default setting. Without the BIOS password.
Apr 14, 2009 | Computers & Internet
Acer desktop Veriton M420, cannot disable chassis intrusion....
I'm surprised the CMOS reset didn't work. Try plugging the chassis intrusion trigger back in and then clearing CMOS and restarting, it may be looking for it there and refusing to start when it doesn't see it. Once you get it back up and running, contact Acer and demand a fix for that terrible chassis intrustion crud.
Mar 16, 2009 | Acer Veriton 6800 PC Desktop
Resetting the bios password a on acer travelmate 2356xm
This web link will give you different options on resetting and clearing the bios password. The easest way is taking out the battery if not smoldered in for 30 min. then on post boot press f2 to get to bios.
http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
Jul 14, 2008 | Acer Computers & Internet
Doesn't boot up
I think you cmos battery is dying... try to replace it.. and configure your cmos bios at exact date and time...
Mar 14, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
219 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
