Have a LLR6233ANO WHIRLPOOL THAT WILL NOT RUN THRU AN AGITATION CYCLE OF THE WASH AND MAKES A LOW BUZZING NOISE DURING THIS CYCLE IT DOES FILL AND DO THE RINSE/SPIN CYCLE HAVE LOOKED FOR INFO BUT CANT FIND ANY HELP
ginko
  • 19396 Answers
SOURCE: Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Posted on Nov 20, 2008
    honeymokey
    • 3113 Answers
    SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
    Lid switch. Push down on lid.
    Posted on Jun 18, 2009
    Maytag317
    • 1136 Answers
    SOURCE: Will not spin on any rinse cycle
    Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
    If you will get me a model #, I can look this up for you and give you a better idea.
    Vic
    Posted on Jul 05, 2009
    SOURCE: no agitation in ge hydrowave rinse cycles
    you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
    Posted on Jan 21, 2010
    heatman101
    • 43501 Answers
    SOURCE: whirlpool Model: WTW57ESVW0 will not
    If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
    Washing Machine Problems No Water
    Washing Machine Fix Washing Machine No Water
    heatman101
    Posted on May 01, 2011
    A knocking noise during agitation wash cycle
    could be a bad counter balance , u can remove the front panel and run a spin or wash cycle and listen to where its coming from so u don't have to replace all the balancers. on some models theres a heavy ceramic weight at bottom that at times goes bad and throws it off balance, just run it and look where noise is coming from
    Jul 25, 2014 | Maytag Performa PAV2200
    Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
    Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
    Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
    My GLTF 2940 makes a buzzing sound like a relay not pulling in all the way, during the rinse cycle. If you shut off the washer, and restart it on the rinse only cycle, it goes away.
    its probably your cold water rinse only valves solenoid thats loose on the structure or the coil itself is loose,you may not hear it all the time especially during the initial wash start fill,try this, set the washer for cold water fill only on the washer,but turn off the water valves that supply water and start your machine to a wash cycle as normal,try this and see if it dry buzzes(without water),then try the same on the hot side,then with the water still off open up the machine and you can localize the buzzing noise
    Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
    Doesn't Wash Clothes, But It Rinses Clothes
    hello. i can help you.
    Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
    Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
    Jun 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    GE top loading wash machine makes noise during agitation cycle...
    look in your basket of washer see if you see anything stuck in the hole ok
    Oct 20, 2017 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
    Washing machine makes a clanging sound during agitation/spin
    Without being there to physically see what it's doing or hear the sound, I would say there's 3 possibilities. 1) drive block is slipping on basket drive / brake assembly. 2) basket drive assembly is worn where drive block seats onto it. 3) clutch slipping.
    Sep 26, 2017 | Whirlpool Washing Machines
    Washing machine makes buzzing noise
    Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
    Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
    Thumping/knocking/rattles during wash agitation cycle
    Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
    Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
    Loud buzzing noise throu8ghout cycle. Sometimes washer sticks in wash mode
    first thing i would check is to make sure your copper water line is not touching the motor this will give you this noise. just take off lower kick plate and start d/w you will be able to tell where the noise is coming from.
    Nov 28, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
    Washer make a clicking noise
    Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
    Nov 30, 2006 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
    Washing Machines Logo
    177 people viewed this question
    Top Washing Machines Experts
