Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Convergence is scrambled due to power outage. how do i use remote control to get into service mode to do a "course convergence adjustment" ?
  • Panasonic Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
convergence is scrambled due to - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 03, 2010
Colors are seperated on toshiba 50A61
Go into menu and with original remote call up convergence--either it has a problem(will not adjust) or you may with the remote be able to manually adjust the convergence back: sometimes if a power outage/surge it scrambles the convergence memory.
Aug 28, 2012 | Toshiba Televison & Video
Tip
ERVICE MODE AND POWER SUPPLY CIRCUIT
SERVICE MODE AND POWER SUPPLY CIRCUIT
Purpose: To bring the color adjustment of each component into standard alignment.
Symptom of Misadjustment: If this adjustment is incorrect, component signals do not reproduce the corresponding color.
1. Input 1080i 100% Color Bar signal.
2. Enter the service mode.
3. To enter the Auto Calibration adjustment mode, press [6] button on service the remote control unit.
4. To start auto adjustment, press [1] button on the service remote control unit.
- In the auto adjustment mode, "Please wait" appears on the screen.
- Upon completion, "OK" appears on the screen.
TO KNOW MORE CHECK THE LINK BELLOW
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
on Feb 18, 2015 | Emerson Used Original LC195EM82 Remote...
What is the procedure to do color convergence on a hitachi 50vs69a
Almost all you can either get into the mode by use of the remote or remove front speaker grill and inspection plate behind it, there is a tiny blue push switch which will put you in the convergence adjustment mode, then various buttons on the remote do different things and save the adjustments.
Of course if convergence will not adjust you have a bad chip and this model uses two so both get replaced in that case.
Aug 27, 2012 | Hitachi 50VS69 50" Projection HDTV
Convergence problem
reset your tv with defaults settings.f chip and resstor blown then it need change.
Jan 06, 2009 | Philips 55PP9401 55" Rear Projection...
Convergence scrambled..how do i use remote to get to service mode
this is going to take you some work ,do you have a hotmail address that I could send you the procedure?
Dec 10, 2008 | Panasonic PT-47WX53 47" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Service mode for convergence
You enter the service menu by using the remote. Press DISPLAY, 5, VOL+, POWER in rapid succession. Once the screen appears, you should notice green letters and numbers at the top of the screen. Your remote acts as a navigation tool to allow you to select and change values. Keys 1 and 4 change the Item, keys 2 and 5 change the Category, and keys 3 and 6 change the Value. MUTE enters the write function, and ENTER executes it. Power exits the service menu. Keep in mind that while in the convergence mode, the keys have different functions, which we'll get to in due time. The service manual will also have this information.
http://tv.groups.yahoo.com/group/Ws500/
Feb 16, 2008 | Sony KP-51HW40 51" Rear Projection...
Convergence
Replaced convergance power packs (2) stk392-110 check all 2watt resistor the packs, to enter the convergance alinment mode on the set. Using the remote control press and release the sleep timer button when sleep timer displays timer equals zero immediately press the display and V. status buttons at the same time.  If done quickly enough the service menu will appear once entered the careful not to does disturb or change any other settings press the number seven to enter the convergence alignment mode a full crosshair pattern will appear in this alignment mode you can adjust the blue and the red to line them on the green using the select and the number pad you can move to the next crosshair to align the boot to the green and then the red to the green when done pressing the muting button on the remote control will save your changes will take a little while to figure this out as you work with.  If you make an unwanted error pressing exit without hitting the muting button will restore your convergence to its previous  setting.  If you're green is off after entering the service mode press the number six on your remote control in this setting will be able to adjust the green only once that is done us the muting button.  Then enter button seven if need be to adjust the blue and the red.  Remember no changes have been stored until the muting button is pushed open this helps.
Oct 14, 2007 | JVC AV-48WP30 48" Rear Projection...
Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Aug 10, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Loss of convergence after powering off.
you must enter the service mode and align your convergence and save it to the epromm also activate the auto focus to activate the sensors , power on /mute-1-8-2- / press enter to save and before you exit activate the focus key on the remote ,very inportant to do the last step./g
Apr 29, 2007 | Samsung PCN5425R 54" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
