Mitsubishi WS-55809 55 in. Rear Projection Television
Problem for Mitsubishi WS-55809 55 in. Rear Projection Television
I have a Mitsubishi WS-55809
By cbolitho on Dec 10, 2008
I have a Mitsubishi WS-55809 with convergence issues, I found the correct IC's I should be putting in but I have zero experience with installing it/them. I don't have the money to get this fixed thus I have to do this myself. I am getting a headache looking at the tv so I have to do something now. I am semi technical so a quick how-to on what to do should suffice. Thank you!
Same Problem
Mar 20, 2009
-   same problem same tv and model # were do you get the parts for this golfercb@aol.com -   Guest
Solution #1
posted on Dec 10, 2008
Not Rated)
ladywinn
Rank: Guru  Televisions & Videos  Expert
Rating: 86%, 857 votes
If you know how to Solder then you have it made if not find someone who can ! Also ck low ohm resistors they can be bad or opened 1.8 ohms 2,7 ohms ect.......
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-55809 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55809 55 in.
Do you recommend Mitsubishi WS-55809 55 in. Rear Projection Television?
Answer
Answer
the picture is bowed and has a rainbow affect around the edges
Answer
Mitsu Medallion 1080HD rear projection TV. The color is bowing from top to bottom (2 colors). Also,... (More)
Answer
change convergence chips works great no curved lines but cant complety get all of green ghost out of... (More)
Answer
Trying to figure out to find my television code for media center Mitsuibishi Medallion CRT
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-55809 55 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
