Question about RCA Audio Players & Recorders
I got water on my mp3 and ever since when i try to turn it on it shuts down its malfunction but i think if i put some new drivers to my mp3 it would be fixed again can you help me please =<
    President:
  • 373 Answers
Once water falls on an mp3 player, the first step is to remove the screws behind and let the components dry.especially the battery.This avoids any shorting in the circuitry.
If this does not help then the only reason for the malfunction is one of the components has been fried dude to being shorted.
Contact your vendor if the warrenty still exists.Else you might have to repair the entire player.
Do not continue using the player if the problem continues for now.
hope this works out.thanks for contactin us.Please do rate fixya if the problem is solved.
Posted on Dec 10, 2008
What can i do when water is inside my mp3 player, then i lost it for a month. when i found it , i immidiaetly plugged it into my computer, it started working. i let it charge. when i took it out, it...
Good morning, afternoon, evening or night; whatever time of day you are viewing this post. Thank you for choosing FixYa to assist you with your problem. Your MP3 Player has been exposed to water, then it gets lost, you find it and immediately plug it into your computer for it to charge and start working again, then it shuts off after you unplug it from the PC. I don't know if you know this or ever read it in user manuals, but they tell you not to expose your electronic device to liquid substances. This can cause product failure as well as harm to yourself or others. I'm surprised it's still working when you plugged it into the computer. I had a flash drive that went through the same experience as your MP3 player: got lost and was exposed to rainwater, then was found later and started to work again once it was plugged into the computer. Later on though, the computer failed to recognize it and it eventually stopped working. I'm thinking the situation with your MP3 player is that the battery or a driver controlling battery functioning, is defective due to water exposure. The driver that controls the PC launch up, may not have been exposed to it as much. You could try opening your MP3 player (if it can be opened) and try to drain all the water out of it, then put it back together and try to turn it on again. If that doesn't work, plug your device into the computer and go to the device manager on your PC. If your computer recognizes the device, go to its properties and click the driver tab. Click "Update Driver" to see if a driver update is needed. If the driver is up-to-date, try uninstalling the driver, then reinstalling it again. If your device is not working properly after this. Then the battery, driver or other electronic circuitry inside of your MP3 player is defective. You can try to replace the battery, if it can be, to see if that makes the difference, but I'm pretty sure your MP3 player is defective now. I'm sorry for the inconvenience, but thanks for choosing FixYa to assist you with your problem. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
May 23, 2011 | Audio Players & Recorders
1991 Jeep Cherokee Limited starts, runs a few minutes then dies
Running for five minutes sounds like something other than a security system problem (usually shuts off much earlier) but if that has been compromised it needs to be put back together or the trigger wire from the drivers door lock needs to be grounded.
I'd look to the throttle position sensor, map sensor, crank position sensor or the ballast resistor on the drivers fender. You need to do tests on those items as all influence the fuel management system after warm up. Test when it is cold and after it shuts off so you don't mistake a part malfunction only when hot. Hands on testing is the ONLY way to determine accurately exactly what is happening there. Anything else is an educated guess!!!
Mar 11, 2010 | 1991 Jeep Cherokee Limited
This is a brand new product. Every time I turn it on, I get the "shutting down" message and it proceeds to do so. I have tried 2 new batteries.
try to unlock it or reset it there shoulb be a very small hole on the back of it use something to put in there to reset it i try it i dont relly know if i works it justsomething i got off a website but i have delete all of the files off of mine and now it give me some problems because i delete my factory setsing or files so do NOT!! delete the files.
May 24, 2009 | RCA TH1602 MP3 Player
Water doesn't shut off while switch is in an on position.
HI. Yes, you can replace the timer but, i think its a faulty water valve relay. it may be stuck or, malfunctioning.
Mar 20, 2009 | Maytag Washing Machines
I have a new sanza e260,which shuts down my computer
Try re-installing the drivers for the MP3 player FIRST then plug in the MP3 player! Also make sure you have the lates Windows media Player installed
Mar 07, 2009 | SanDisk Sansa e250 MP3 Player
Not syncronizing
go to my computer> properties>hardware > device manager >last one universal bus driver click on it>go to driver and update it
choose only second option when asked
Sep 22, 2008 | MyMusix PD-6070 MP3 Player
Mp3 player malfunctioning.
if ther anther update to firmware out for it uyet try to get it updated otherwise internal switch no good
Feb 03, 2008 | Sears TGE MP3 Player
Pearl mp3 player malfunction.
I have a brand new (2008-2009) hp computer and can not figure out how to download music on it from a cd
Dec 16, 2007 | RCA Lyra RD2765 MP3 Player
Mp3player won't turn on
hi , i have an mp3 player which has been working fine all along. i shut it down,a few minute later trying to put it on only the light is on but nothing displays and sometime just shows sandisk and it hangs it not gives any responce
Mar 31, 2007 | SanDisk Sansa e250 MP3 Player
46 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
