Question about Acer Aspire 5500 5570-2609 Laptop
Not sure if my Aspire 7720-4799 17 inch has lightscribe or not
Checking on Lightscribe
  • 29 Answers
Do you have the software for lightscribe? Also most drives with lightscibe capability are labeled as such on the front of the drive.
Posted on Dec 10, 2008
I would like to install a lightscribe drive , can it be put into the hot swop carrier space witch i don't use
Yes you can add the lightscribe drive to your system as long as you have an open pay (slot) to hold it. If you have a desktop tower, then most likely you have a slot available either right under or above the current dvd/cd drive.
Just make sure your lightscribe drive has the same interface (SATA or IDE) as your current drive or you might need some cable adapters to make it work.
If your system uses IDE (little metal prongs or pins where the cable plugs into the back of the dvd/cd drive) then you want to set the jumper pin on the back of the dvd drive to CS for cable select. If there is a cable ribbon going to the current drive it will have another connection open that you can use for the new drive. Normally the cable ribbon will allow you to piggy back the two drives.
SATA is the latest technology so if your current drive is SATA, and your lightscribe is SATA then look at the two cables that go into the dvd drive already installed. There might be another set that is not being used that you can hook to the lightscribe drive. If so, hook the set to the back of the drive and into the slots on the motherboard.
May 18, 2012 | Acer Aspire M3400 PC Desktop
When I try to label a disc using LightScribe it keeps saying that lightscribe drive not found
First of all make sure your drive is lightscribe capable. Next go to your drive manufacturers website and download the drivers and software for your drive.
Mar 23, 2011 | Computers & Internet
My computer does not recognize my hp 557s as a lightscribe compatible device
Hi professa31!
Have you tried installing the Lightscribe software bundle? Their website says that it's required for operation of any lightscribe device. Here's the link: http://www.lightscribe.com/downloadsection/windows/index.aspx?id=810
Also, it appears that there are a bunch of reasons why it may not be detected, most of which are not bad at all. Here (http://www.lightscribe.com/support/index.aspx?id=401) is a list of a few reasons, from the lightscribe website.
Mar 03, 2011 | HP Hewlett Packard HP DVD557S 8x USB Slim...
Ink won't dry on lightscribe
You need special absorbent coating on the printable DVD's if they are suitable for that. Are you sure you can print on the sort you have usually they are all white. It also must actually say suitable for PC printed labels etc too.
Jun 18, 2010 | Verbatim (95058) 25 Pack 16x DVD-R Storage...
I've installed my lightscribe dvd/cd burner the only disc that came with it was nero 7 essentials i installed that but i cant get it to run the lightscribe when i put the disc in on the side to burn a cd...
You need to use a disk made for Lightscribe. Lightscribe technology was developed by HP.
Look at your local store that handles CD's, and DVD's, and look for the Lightscribe disks.
More information about Lightscribe,
http://en.wikipedia.org/wiki/Lightscribe
Oct 22, 2009 | QPS Que! Fire CD-RW Burner
LightScribe stopped working
its not NEW its , NEW OLD STOCK (NOS)
old lightscribe, drive. the drive that prints labels on top.
NO OS STATED nor any PC stated.. wow.
Lightscribe is mostly not supported now. (read the wiki, on that it dont lie)
obviously and very hard to diagnose.
1-bad drive.
2: bad driver for drive
3: upgrated OS and it dont support this (why post lacking OS)????
4: bad media.
read this.
https://en.wikipedia.org/wiki/LightScribe
then at that bottom read HP unstable.
From HP's official site, they started phasing out Lightscribe drives in HP computers in 2011, due to "industry conditions beyond our control."
windows 8, 8.1 and w10 its not supported.
go to HP.com read what your PC supports, with the unstated
by you PC, and unstated OS
tdk and verbatium stopped making them.
not this is dead now
some get w8 to run with W7 drivers
why not ask at HP. why here?
https://h30434.www3.hp.com/
sure NOS disks are sold rotting on selves... sure.
try google for help? see the words no support?
1st hit
http://www.wikihow.com/Use-LightScribe
Aug 19, 2017 | HP LightScribe dvd640i (DVD640I)...
HOW DO I USE LIGHTSCRIBE? I HAVE A NEW LAPTOP WHICH HAS LIGHTSCRIBE BUT I DON'T KNOW HOW TO USE IT
To use Lightscribe you must get a Lightscribe CD or DVD. If the CD or DVD is Lightscribe compatible, just go to your programs menu scroll to Lightscribe and it leads you through the process. It's a user friendly software.
Please don't forget to rate this
Mar 20, 2009 | HP Pavilion dv6000z Notebook
LightScribe installed properly, but not seen by other software.
Software problem with NERO and Surething LightScribe. Didn't see the "LightScribe' option in thier software.
Droppix Lightscribe software worked fine.
Dec 28, 2008 | HP LightScribe dvd640i (DVD640I)...
My dv9000 wont burn any cds. i am not sure why. i have tryed downloading some different software but it still wont do it. i know it can i have done it before. i also have lightscribe and i have used that...
1. Lightscribe needs its own drivers and a labeler like Surething CD Labeler
http://www.lightscribe.com/downloadSection/windows/index.aspx
2. If your HP came with sonic and you installed Nero or something else there is a good chance neither programs will work.
I had the same issues with my lightscribes (2) I thoughtlessly installed Nero without removing the Sonic Digital Media + in my HP the burner no longer worked, I reinstalled both programs after removal. I had to run the Nero Clean Tool first
http://www.nero.com/eng/support-nero7-tools-utilities.html
before the burner would work again.... only with the Sonic though Nero never did anything but mess up my burner, the lightscribe came back after installing the correct drivers, if your lightscribe is very light almost unseeable, then there is a contrast enhancer for the lightscribe
EXTENDED LABEL CONTRAST UTILITY
http://www.lightscribe.com/downloadsection/Windows/index.aspx?id=812
Sep 19, 2008 | HP Pavilion dv9000z Notebook
Nero 8.3.2.0 cannot communicate with Lightscribe
Please make sure you have the Lightscribe system software installed.
http://lightscribe.com/downloadsection/Windows/index.aspx?id=810
If you install it and still cannot use LightScribe, please post back.
Jun 17, 2008 | ASUS (90N951W1000) DVD-RW Burner
Acer Aspire 5500 5570-2609 Laptop Logo
85 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
