Question about Maytag Neptune FAV6800AW Top Load Washer
Black, tar-like spots on some clothes after wash
After clothes have washe, I'm beginning to notice some small, black, tar-like spots on the clothes. Some of the spots are as small as ground pepper but some are as large as a dime. Where could this be coming from?
  • Paul Woodall Dec 10, 2008
    As it turns out, a repair man has determined that the black spots are actually grease and says it is coming from a leaking seal in the transmission. Thanks anyway, the suggestion for cleaning the outer drum is a good one and I did buy some Affresh. Also, it looks like the transmission is covered by the warranty since I purchased the washer in Dec. of 2004!
  • 20 Answers
Hi
Its probably coming from the outer drum of your machine. That's what holds the water. Your inner drum, what you see, is full of holes and allows the water to pass through in the drum and wash the clothes. that outer drum gets crud in it which then passes through the holes onto your clothes. the easiest way to get rid of it is to get a product called "affresh" from W mart or the big Hardware chains and follow the directions. Good Luck
Posted on Dec 10, 2008
Our tub has some kind of black stuff all over it! It is like tar when we try to wipe it and it just smears. It sticks to the skin and does not wash off easily.
Try to remember the clothes washed prior to this showing up stuck to the drum. The source was something likely left in a pocket. Examine the clothes carefully for the same residue.
Try a small amount of liquid dish soak on a rag and see if it will dissolve into the soap. If not than it may be a silicone base material (black sealant) from something included in a prior wash. Unless there has been plumbing done recently at the house and if no other sink has shown similar characteristics you need to assume that it came in with the wash load.
I would load up the machine with rags and old work clothes set water level to full load set to heavy duty and hot water, Double up on the soap and let the machine do the work of cleaning. It may take a few cycles and a trace residue may always remain.
Nov 30, 2015 | Washing Machines
Black spots and marks on laundry
maby sumthing in the line on the hose dirty tar sumthing weird comming in or are u waching alot greesy clothes
Jan 26, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Small black spots on clothing after being washed, always wash in cold water with spree washing powder, never use any fabric softners
Hi just read your posting.Now are the black spots an oil substance?Or is it flaky and comes off easily?What is the make and model of your machine and is it a top loader or front loader?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 14, 2010 | Washing Machines
Leaving black residue (spots) on clothing
Black spots usually come from the agitator shaft bearing seal which will, when worn, allow oil from the transmission to seep into the wash. Replace the seal, and maybe the upper bearing if the shaft itself will move visibly from side to side in various directions. If the machine is still under warranty, take advantage. Hope this helps!
Apr 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Noticed after I do a load of laundry there are black (grease) spots on my clothes. I found a grease spot on the bottom of tub. What could this be?
its the topseal on the transmission thats leaking,the term for this is called "back-wash" you need a new seal
Feb 03, 2010 | Washing Machines
Tar clothing
I would think you would need to presoak the tar stained clothes in a bucket of hot & Stong detergent water. If you use that stong a detergent in the washer you run the risk of damaging the seals. Either do that or use someone elses washer and drier. Then Run like He..!
Dec 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Oil in the Tub getting on clthes
the oil will be coming from the bearings it usually comes onto clothes as brown rusty colour spots if so change bearings
Dec 20, 2008 | Washing Machines
BLACK TAR-LIKE DEPOSITS INSIDE WASHER BASKET
THE DRUM INCLINE BOTH PLASTIC AND MEATAL SCRATCHING FROM DRUM CAUSE LIKE A CRAYON /SMALL PARTICLES , THE SUPPORT SPRING BESIDE THE DRUM ARE DETACHED NEED TO INSTALL SPRING / AVAILABLE IN APPLIANCES CENTER.
Jan 04, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Black spots on laundry
your problem may be because you generally use a 'cool' wash ie 30' or 40' Try a really HOT programme or two to see if this will remove the deposits that have built up What happens is that quite a lot of 'undisolved powder' tends to congregate inside the machine because of 'low temperature washes' Its a good idea now & then to use CALGON or some other descaling agent.
Mr CALGON please note my plug but it is good
Oct 13, 2007 | Frigidaire GLTF1670A Front Load Washer
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
682 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
