Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Kitchenaid dw clean light still blinking/ machine won't run...
I have the kuds01flss6 dw, about 2yrs old, the kids were caught pressing all kinds of buttons, and now it's locked out.i tried killing the power overnight still the clean led is blinking 4-5 times.any solutions to clear this out?
  • 2 more comments
  • Anonymous Nov 14, 2007
    Hi - I have the same problem with the same d/w. Clean light blinks 7 times. Thanks.
  • cbread Dec 22, 2007
    i have the same problem. i have someone coming to change the heat element in the new year but i need to get through the holidays. is there a way to by pass it for now?
  • Dorrine Apr 28, 2008
    Same problem, clean light flashes 7 times and dishwasher won't start.
    The water is plenty hot enough, can't I bypass this?
  • sammoura69 Jun 17, 2008
    I try to turn on the dishwasher, but the clean LED keeps flashing and the dw wont turn on. the instructions on the door panel say to press the energy save button to clear it. I tried that several times, and still flashing. then I unplugged the dishwasher power and plugged in twice and the problem persists. I looked in the service manual and it says that heating ciruit needs service. Looks to me like the dw is in a locked up state, can I clear that? or if the heating circuit needs repair, im pretty handy, can you advise
I tried the following sequence, as recommended on a similar blog and it worked!
Open door
Quickly press :
Hi Temp Scrub
Energy Saver Dri or Heat Dri
Hi Temp Scrub
Energy Saver Dri or Heat Dry
Close door
All lights should come on
then clear and revert to cycle.
Posted on Aug 10, 2009
  • 2 more comments
  • kjleonaed1 Apr 04, 2011
    took me a 2 days to find the right code this worked great, thanks for the post
  • Dianna B Aug 14, 2011
    A month ago our dishwasher was working just fine and suddenly decided it wouldn't start anymore. After being without the dishwasher now for about a month and out of town, home again we decided to see if we could get it to work again. Reading all of the comments posted, first, since the dishwasher is hardwired, we turned off the power at the breaker for about 15 minutes. That didn't do anything. We took the kick panel off and there was nothing there to tell us what to do. I read here of the 'code' to use and it acts like its going to work but when I push the 'normal' button, it clicks over to 'rinse only' and back to 'normal' then back to 'rinse only' and it rinses the dishes. The dishwasher only stays on for about 3 minutes, rinsing. Then nothing again. When it first went out a month ago, I called KitchenAide and they said that there is no longer a keypad available for this model. And the girl said that IF I could find one, it would probably cost about $350 for the part and a technician would have to replace it. She wasn't very encouraging nor was she helpful. If the part costs that much, and if I had the money, I would BUY a new dishwasher and I don't know that I would buy another KitchenAide only because of the twit that I had to speak to when I called in. Does anyone have any other suggestions or know of where I could find an inexpensive keypad? Thanks in advance for the help.
  • dino menna
    dino menna Jan 29, 2012
    thank you!!!she work now!
  • juliegravis
    juliegravis Oct 21, 2012
    This worked! Thank you soooo much...have a load washing right now!
Had the same problem and just fixed it myself.Have the door shut then open just a crack and within 3 seconds press high temp scrub and then the energy save button and then the high temp scrub and the energy save button again close door and press cancel.It worked right away.Sometimes it happens because there is another problem.So if it happens again it means there is another issue
Posted on Jan 20, 2009
    Scholar:
  • 76 Answers
Salvy Control is programmed to stop the current cycle and not allow any further cycles if it suspects a faulty heater (no temperature increase detected in heated intervals). Control blinks the Clean LED 7 times in repetitive fashion and disables the Start/Resume button. There could be three parts involved in this problem. If you feel like you can do it yourself, let me know and I'll give you step by step instructions. Also, you can find the trobleshooting procedure in a pouch attached to the back of the bottom panel. You have to remove two screws to open it. Gendos...post back
Posted on Mar 02, 2007
Fixya.com-does not know anything they play guessing games
Posted on Apr 02, 2011
Clean light blinking
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
Kitchen aid dw won't start,, the lights come on it beeps at me but won't start the cycle... also, during a cycle i can open the door and it doesnt halt the cycle, it just keeps on going
see this causes:
Power from the house
reset the c.breaker from your hose or replace blown fuse inside the machine.
Door switch
test the door switch for open or defective this will NOT permit to close the relais for start the motor
Wiring
loose wiring, break or burn repair
Timer or selector switch
selector switch, open or defective, timer defective, however clean contacts diryt or oxide, loose wires, break or burn. GOD BLESS YOU.
Jun 21, 2012 | KitchenAid Dishwashers
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
Clean light flashes on my KitchenAid KUDS01DJ and it wont run
My dishwasher did the same thing. The repair guy fixed it and told us how to reset next time it happens: press: Hi temp then Energy saver then Hi Temp then Energy saver do this quickly over 5 seconds all the lights should come on Then,turn off the breaker for one minute then, go back to the dishwasher and press cancel. All the lights should turn off. Start dishwasher as usual. If the cause was just a brain fart, the dishwasher should work.
Jun 03, 2010 | KitchenAid KUDS01DJ - Multiple Color...
We have a kitchenaide dishwasher and the clean light keeps blinking off and on and the dishwasher won't work. Of course it is Thanksgiving and I have a house full of people coming over! Any ideas?...
you can try to kill the power to dw and with 15 minutes before supplying power back and see if it will reset your control, if not you will need a new control board / thanks
Nov 27, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Nov 16, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
Open the dishwasher door, press in rapid sequence the following keys: Hi Temp Scrub, Energy Saver Dry, High Temp Scrub, Energy Saver Dry. Close the door until it latches and press the Cancel key. The machine should reset itself. It worked for me when I had the same problem
Oct 20, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean led keeps blinking.
salvy, look for the lock symbol, it should be on the heated dry pad. Press and hold it until the lock led turns off. Catriver..post back.
Mar 14, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid dw won't go on
Salvy, see if you can get out of that fault by pressing, in this order within 6 seconds. Heated dry-normal-heated dry-normal. If you don't have those keys try- high temp-air dry-high temp-air dry. This is the service cycle, all lights should light up and the unit should go into a self test and clear the fault. The test lasts for about 25 minutes. Let us know it this works, Catriver..post back.
Feb 28, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
2,491 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
