Question about AT&T Blackberry Curve 8300 Smartphone
Camera on blackberry 8320
Hello, whenever i try to select the camera a message appear "could not start the camera, try closing all applications". How do i fix this problem
  • adixon176 Feb 01, 2009
    I have this same problem. Can someone please help?
I have the same problem...But the thing is I bought it from eBay. Can someone help me too?
Posted on Dec 29, 2009
I have a Blackberry Bold 9700 from AT&T and the camera will not start. Whenever I go to activate the camera it shows the following error message: "Could not start the camera. Close other...
It has been known about Blackberry smartphones to have missing components and programs over time. Normally it is due to other programs downloaded and installed into the phone causing complicated incompatibility issues. You can either try to disable those programs on the settings or much better to restore your phone. Hope it works for you.
Cheers!
Mar 28, 2011 | RIM BlackBerry Bold 9700 Smartphone
I have blackberry 8110 showing jum error 547
Hi, you need the desktop manager, and you need to download the current software version for that device, its going to wipe everything out on the device, but you will get the device to work. after you download the the software, you need to run it on your PC, and then use the APP loader on the desktop manager to install it to the device.
Step #1 Before starting make sure that BlackBerry Desktop Software is installed on the computer.
Step#2 Make sure that you have installed updated device software installed in your PC.
Step#3 Users can perform a full or selective backup of the data using the Backup and Restore tool in BlackBerry Desktop Manager by completing the following steps: Connect the BlackBerry device to the computer running BlackBerry Desktop Manager. Open BlackBerry Desktop Manager. Double-click Backup and Restore. Select Backup to perform a full backup or select Advanced to perform a backup of specific databases. Choose a location to save the backup file, then click Save.
Step#4 To perform a clean install of the BlackBerry Device Software, perform the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click the Application Loader icon. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Click the check boxes next to the names of the applications you want to load, and then click Next. Click Advanced, and then click the check box beside Erase all currently installed applications. Click Next. Click the check box next to Do not automatically backup the application data during the loading process. Clear the box next to Backup and restore applications installed wirelessly. Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
Feb 23, 2011 | RIM Blackberry 8310 8320 8330 Curve 8100...
My blackberry is just sayingblockerase6 Reset
The Block Erase 6 Reset error may result from corrupt data on your BlackBerry device.
To resolve this problem, you need to complete the steps:
Reload the BlackBerry Device Software by following these steps:
  1. Install the BlackBerry Device Software on your computer.
  2. Connect the BlackBerry device to the computer.
  3. Open BlackBerry Desktop Manager.
  4. Complete one of the following:
    1. If the Application Updates Available window appears, click Update Now. The Application Loader wizard appears.
    2. If the Application Updates Available window does not appear, double-click Application Loader. The Application Loader wizard appears.
  5. Click Next.
  6. If prompted, enter your BlackBerry device password and click Next.
    When the Application Loader wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation.
  7. Select the check boxes next to the applications you want to load. Check boxes that are already selected represent applications that already exist on the BlackBerry device. If you clear those check boxes, the applications will be removed from the BlackBerry device.
  8. Click Next.
  9. If the On the Device Backup screen appears, choose whether or not to automatically back up the BlackBerry device.
  10. Click Next.
  11. Click Finish to begin loading the BlackBerry Device Software.
  12. Click Close when the software is finished loading.
Inspite of this if you find the same error, you need to follow the steps:
  1. Remove the battery from the BlackBerry device.
  2. If a media card is inserted in the BlackBerry device, remove it.
  3. Connect the BlackBerry device to your computer using the USB cable.
  4. Open BlackBerry Desktop Manager and click Option > Connection Settings.
  5. In the Connection Settings window, click Detect. Make sure the BlackBerry device is detected.
  6. Close the Connection Settings window.
  7. In BlackBerry Desktop Manager, double-click Application Loader.
  8. In the Application Loader wizard, click Next to start the loading process. The Device Application Selection screen appears displaying the applications available to load onto your BlackBerry device.
  9. Select the check boxes next to the applications you want to load. Check boxes that are already selected represent applications that already exist on the BlackBerry device. If you clear those check boxes, the applications will be removed from the BlackBerry device.
  10. Click Next. The Completing the Application Loader Wizard appears listing the applications to be installed and removed from the BlackBerry device.
  11. Click Advanced.
  12. Select the Erase all application data check box, and then click Next.
  13. Select the check box beside Do not automatically backup the application data during the loading process. This check box is selected because the data on the BlackBerry device may be corrupt.
  14. Reinsert the battery into the BlackBerry device.
  15. On the Application Loader wizard, click Next to proceed with the loading process.
  16. When the process is complete, the Application Loader wizard will display the following message: The loading operation was successful.
  17. Reinsert the media card if one was removed earlier.
  18. Close the Application Loader wizard.
Nov 16, 2009 | RIM BlackBerry 7290
Blackberry camera repair
This is not a software problem.
The camera got knock off contact inside the Blackberry.
There is a EZ fix and you can give it a try.
1)Power off the BlackBerry
2)take the back cover off //take the battery out
3)clean the camera with a DRY clean cloth
4)apply gentle pressure around the camera
you may or may not hear a popping sound
this is the sound the camera making contact with the socket.
REMEMBER USE LIGHT PRESSURE
5)place battery and cover back on
6)power on the Blackberry
7)try the camera function
IF YOU ARE GETTING off color or ghost like pic then you are have way there!
Good luck
Oct 29, 2009 | Cell Phones
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Battery not holding charge
Hi
Please Reload the BlackBerry Device Software using Application Loader.
Following are the steps.
Note:The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding
BlackBerry Device Software using BlackBerry Desktop Manager version 4.5 to 5.0, perform the following step
  1. Open BlackBerry Desktop Manager.
  2. Click Help
  3. Select About Desktop Manager
  4. Click the Device Software tab
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider
  6. Connect the BlackBerry smartphone to the computer and open the BlackBerry Desktop Manager.
  7. Double-click Application
  8. Click Start under Update Software to start the installation process.
  9. Type your BlackBerry smartphone password, if prompted, and click OK.
  10. Select Options under Device Software Options.
  11. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  12. Click OK > Next > Finish.
  13. When the process has completed, the message The loading operation was successful will appear. Click Close to return to the BlackBerry Desktop Manager.
  14. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  15. Click Finish.
  16. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
Please Rate and feel free to contact me
Sep 22, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry curve 8320 camera
Take the battery cover off. Take your finger and press on the lens area (below the flash) you should hear a "snap". Don;t over do it though.
Jul 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
App error 523
On the BlackBerry smartphone, the following error message appears after pressing the mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
To resolve this issue, the BlackBerry Device software will have to be reloaded.
Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry Desktop Manager. Please proceed to open and run the Application Loader.
Jun 29, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
(french)i have bberry curve 8330 and i receive a eror code 205..
If it is application error then follow these steps: Warning: You should not install a version of BlackBerry Device Software that is earlier than the version installed on the BlackBerry smartphone. Doing so could cause the BlackBerry smartphone to malfunction. Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the computer by completing the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications you want to load, and then click Next. Click Advanced, and then select the check boxes beside Erase all application data and Erase all currently installed applications . Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager Note: BlackBerry Desktop Manager 4.3 will display the Delete all application data and Delete all currently installed applications check boxes in step 6 of the above procedure. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Add/Remove Applications. Type your BlackBerry smartphone password and click OK. Select the check boxes next to the names of the applications you want to load. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Click OK. Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager. Note: The Delete all application data and Delete all currently installed applications options are not available when using the Application Loader in BlackBerry Desktop Manager 4.5. A workaround for this issue is to use the Application Loader standalone file by performing the following steps: Open My Computer (or Computer in Windows® Vista?). Navigate to C:\Program Files\Common Files\Research In Motion\AppLoader. Run the Loader.exe file and follow steps 3 through 9 above to complete a clean installation of the BlackBerry Device Software.
Jun 09, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
AT&T Blackberry Curve 8300 Smartphone Logo
136 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
