When i connect my usb modem to the port the hardware device is not detected either on mycomputer or on notification area but the device is working properly and safely removal of device is not possible since there is no detection of hardware device.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
There may be some sorts of tech error while u install .
Posted on Dec 10, 2008
Tip
Tutorial to connect lg phone to a P C
<b>This tutorial works for most of d lg cellphones which don't provide a dedicated application to make our task easy.... <br /></b>Generally frm LG mobile official website (<a href="http://www.lgmobile.com">http://www.lgmobile.com</a> <span>[nofollow]</span>), we don't get pc-suite like nokia to make our tasks easy, dey just provide USB modem driver for recognising ur mobile....<br />Requirement,<br />A LG cellphone, a usb cable, usb modem driver frm LG website.........<br /><br />Steps-<br />1-connect ur mobile & ur OS will ask u to install driver for nw hardware found<br />2-Locate d downloaded driver and install it as prompted....<br />3-Go to device manager (type devmgmt.msc in run box frm start menu)<br />4- Look for ur new device installed under com & ports section & note com port no...<br />5- go to control panel - phone & modem option- add - select- "don't detect my modem" - next- under standard modem types - select standard 33600bps modem- next- select d com port u noticed in step -4 - next/ok<br /><br />Now check if everything is ok by selecting now installed modem - properties- diagnostics - query modem........<br /><br />Now follow d procedure mentioned in d above post by admin to set up gprs connection........
on Jan 29, 2011 | Cell Phones
The laptop can not detect device when you try to connect the GPRS 3g
Try connecting it to a different port.
Also check whether your USB ports are working using any USB devices.
If the ports are working and the 3G modem is not getting detected, then you should try replacing the modem.
May 24, 2011 | Fujitsu ESPRIMO MOBILE V5515 V5555 V5535...
My usb modem [lemon 3g] does not get detected. when i plug the modem it does not show anything i.e usb icon detected hardware etc. when i clikc on cmy computer also it does not show any connection why is...
First, check for the power source, there should be a light indicator on the panel of the modem, else, power is a problem, check your adapter/power cable. Next, is use USB cable/USB port, try to use other USB cable/USB port. Another option is to check your Control Panel - Device Manager, see if there is a USB Modem currently installed. Remove/delete the device from your Device Manager. Going back to Control Panel, select Add Hardware. If still fails to detect, your Modem is dead.
Good luck.
TedMac
Sep 18, 2010 | Computers & Internet
I have connected my 4Gb Usb Device to my PC, But
insert the usb drive
if a notification bubble appears click it
a dialog box appears showing the new hardware found
click on the detect automatically button.
it starts searching..
if the driver is in r system it installs
if not download the driver from net
write the device model number and company
check ur usb port......
try using in ur friends computer
Mar 11, 2010 | HHP ImageTeam 4710 Barcode Scanner
My Tata Photon Plus USB Modem is not being detected in my laptop. Previously it used to work (for almost 3 months). But now all of a sudden,it is not being detected no matter what. It works on my other...
I just solved the same problem on my laptop with the help of Tata's tech support -
first, plug in the Photon plus modem, remove any other usb devices (mouse, etc)
right click on My Computer, select "manage". Click on Device Manager, expand the list of Serial Bus Conductors.
Right click on each "USB Composite hub" (not root hub) and uninstall.
after all composite hubs are uninstalled, go to the "computer" section at the top of the list in the Computer Management box. Right-click on "Computer" and click on "scan for hardware changes". Yiur system will reinstall the drivers and give you a notification at the bottom right corner of your monitor. Once u get the message "drivers successfully installed", open the Photon plus dialler and connect. It worked for me, hope it works for you too!
Jan 28, 2010 | Computers & Internet
My a4-tech camera was not working..i connect it to the USB port and its not detect
That may be not enough just to connect the camera. Sometimes it is necessary to install proper driver first (even before connecting camera to USB). You can check: http://www.a4tech.com/ennew/downloads.asp
You can check the installation of the device: connect the camera, right click on MyComputer, choose Properties, then Hardware, find your device in the list, double click it - that will show you status of the device: either it is working properly or not. If not you may need to update the driver, or even completely uninstall the device and install it again from scratch.
Of course, there is a chance that device is broken, but hopefully it is not the case.
Good luck.
Oct 05, 2009 | Computers & Internet
Hardware detection problem
Can you explain a bit better? Sometiems it's detected, but there's no detection?
Try plugging it back in. Go to Start: Run: devmgmt.msc orStart: bar at the bottom, type devmgmt.msc ... Look at your devices, look at whether anything has a warning sign next to it.
Links to driver updates are here:
http://www.fixya.com/support/t1381478-webcam_not_working
Dec 10, 2008 | Compaq Presario C700T Notebook
Hardware device detection
Answer posted in duplicate message to this:
http://www.fixya.com/support/t1358051-hardware_detection_problem
USB powerloss?
As you have already stated that the port in question can run a standard optical mouse, the port seems to be working fine.
Sometimes the drivers for a USB device need to be installed for each USB port. Maybe you have installed these drivers for 3 of your 4 USB ports, but not for the one in question, result of which is the problem you face.
Oct 16, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
