Question about Krups FME4 Coffee Maker
Door spring came off filter basket door on Krups FME4 coffee mak
The filter basket door came off my machine. I was able to put the door back on, but I have a metal spring clip and can't figure out exactly where it fits on the basket door/body of the coffee maker. can you help?
  • JaneAuger Dec 15, 2008
    Tried for 2 hours - can't get the spring back on.  Any pictures or diagrams to help?
  • razan1 Dec 20, 2008
    I finally messed with my coffee maker enough that I figured out where the spring goes back in.
    The filter basket door has to be completely off to put the spring back.
    The spring mounts vertically in the hinge area of the filter basket door with the short piece (at the top) horizontally pointing toward the rear of the machine.
    There is a hole at the bottom of the hinged area of the door to locate the spring and a hole at the top with a slot and you push the top of the spring through the slot and into the hole.
    Now comes the tricky part. There are two plastic tabs that hold the top center of the front of the coffee maker in place. The one on the left was already out of position on mine which is what allowed the door to fall off in the first place. The top center section on my machine is silver.
    Both of these tabs must be released in front to allow placing the horizontal piece of the spring into place.
    You then put the bottom peg of the basket door into its hole and then lean the basket door up toward the top hole. Before engaging the top peg of the door you insert the horizontal portion of the spring into a recessed area on the top left of the coffee maker that was exposed when you released the two plastic tabs. Then engage the top peg of the door.
    This was a little tricky the spring popped out on me and it took me four of five tries.
    Keep trying. You can get it.
    Once the door is in place, reengage the two plastic tabs and you are done. Mine works fine now.
    Good luck,
    Randy
    Genius:
  • 1,199 Answers
Yhere should be a little post th spring goes on in the vack of the basket ...out in pkace hold untill in place
Posted on Dec 10, 2008
How do I descale this coffee maker(FME4) if it won't brew because it thinks there's no water. I put vinegar into the water reservoir as directed but how do I get the machine to start.
you just do the same thing as if you are making a coffee but if you don't have the water pump working you will have problems getting the water out
Oct 12, 2014 | Krups Coffee Makers & Espresso Machines
Cuisinart grind & brew - spring in the filter area popped out. not sure where it goes?
Yes, you place the spring into the tube at the back. When you replace the basket holder, make certain you reach in behind the holder and guide the spring into the proper place on the holder. (Otherwise the spring will be forced to a permanent bend and not work as well. Can't find replacements for this spring on Cuisinart's website).
As for why it pops out better now, when you removed the basket holder and cleaned it, you also cleaned the plastic guides on each side. In normal use, these guides acculuminate coffee and tend to get sticky or gummy. When the door pops open, the sticky rails grab the guides and slow the sliding action.
Cleaning them restores the clean guide rails to slide open on. (Next time you clean the basket holder, remember to reach in and wipe out all the inner parts, including the plastic rails that the basket holder slides out on. These get coated with coffee as well. And the place around where the grind basket fits over the ground basket. This area always gets sticky with old coffee. Just use a wet paper towel and clean everything. (But remember to be careful when you reinstall the basket holder so that the spring fits back properly.
Dec 04, 2017 | Cuisinart Grind and Brew 10 Cup Coffee...
Door popped off my Krups FME4 drip coffeemaker.
Just had the same problem today so I thought I would share with you how to fix it. The spring runs up through the door that opens, pop off the silver top and the wire where it makes a L, lock it into the top and put the silver top back on. The switch on the right is only to hold the door open. Good luck.
May 06, 2010 | Krups FME4 Coffee Maker
I have a krups coffemaker model 264A with a broken filter basket. Are these filters still available for purchase?
I have the same problem for the same Krups model 264A duo coffee maker. Does anyone know where I can buy a filter basket for this now-discontinued coffee maker?
Feb 15, 2010 | Krups Coffee Makers & Espresso Machines
I am needing the double sensor (don't know what
those are named "contact thermostat" why you think they are brocken?
Feb 14, 2010 | Krups FME4 Coffee Maker
On FME4 coffee maker the error message CALC
it means de"CALC"ify its detecting calcium build up the manual says to run white vinegar without the filter followed by two clean water cycles goto krups.com to download the manual
Oct 10, 2009 | Krups FME4 Coffee Maker
Filter Basket pops open while grinding and brewing
Put the handle to the basket, that holds the coffee grounds toward the front.  If it is not facing front it will pop open.
Jul 14, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I lost my manual for krups fme4 and i need to set the time of day can u help me
go to the krups website and download the manual:
go to consumer service, then instructions---maybe this link will work:
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={FA4AA2D9-9799-4F8F-8136-8FEB029407FD}&SelectedProdRef=FME4
Jan 12, 2009 | Krups FME4 Coffee Maker
Spring came out - where does it go?
That is from your dripp stop. If you can replace it it will be in the bottom of your filter holder. If not Please tkae out the valve on the bottom of this filter holder. You will have no dripp stop but it will work just fine.
Jun 01, 2008 | Krups Aroma Control 197 Coffee Maker
The display reads CALC.
I have a Krups model FME4 and it means that you should descale the machine. Here's a link to the use and care instructions for my model, I assume it would be the same for yours.
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Use+and+Care/ResultUseAndCare.htm?SelectedService=Use%20and%20Care&SelectedGuIDService={EC10140D-AA43-4DCA-8D3A-A5A4823D9E52}&SelectedProdRef=FME4
My problem is that CALC continues to display even after I've descaled several times. Good luck with yours.
Oct 30, 2007 | Krups ProAroma 453-42 Coffee Maker
Krups FME4 Coffee Maker Logo
1,001 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
