Question about Whirlpool GH8155XM Microwave Oven
GE Microwave does not heat and makes loud buzzing noise.
I have GE model # JVM1660WB. I had the same problen about 1-2 years ago, and replaced the magnitron, diode, and stir plate which all came in a kit. Worked fine until now. This time I replaced with same kit and it only worked one time when I tested with a cup of water. Next day when reheating leftovers, it started buzzing and not heating again. I believe both diodes are shorted, but think the mags are good. What is causing the diodes to short? Also the fuses do not blow like some of the other problems I have seen on this site.
  • Gus May 11, 2010
    If you are blowing diodes, you have a High voltage issue. Basically inverter or transformer is operating without any connected output. Suggest you continuity test the capacitor if fitted also the magnetron for any resistance to casing. This will highlight any potential shorts.
I have just replaced the magnatrton for a Kenmore microwave model # 665.606.5900 as before replacing the part there is still the buzzing sound and non-heating
Posted on Jul 20, 2013
4 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: HV diode producing resistance of 10 ohms.
you cannot check a microwave diode with just a mutli meter . you have to make a test jig take a 9 volt battery and a meter with dc volt scale set up the meter just like you would test a 9v battery .with me so far ? now remove one lead from the battery and insert the diode between the battery and the test lead .......take a reading . now reverse the diode take a reading ........ i just tested a diode before writeing this and this is what i got my battey volts where 9.2 v whith the diode inserted i got 7volts . reversing it i got .02 volts dc . a diode is a one way valve and mine is good because it passed curent only one way ...yours should be about the same ....... if you understand this please leave me 4 stars ! i even went out in the shop and tested a diode for you just to make sure my answer was correct
Posted on Mar 07, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: JVM1650SH02 keeps shorting out after a couple seconds
> but he would also replace the capacitor and diod when replacing the mag tube
Most of the time replacxing them all is done due to ignorance about how to actually test devices, a mistaken notion that it's somehow necessary, or to pad the bill.
The diode may be necessary in some cases (if it tests bad) but the capacitor is almost certainly not needed.
When a capacitor fails, it almost always shorts. If so, the fuse would blow when you peress "Start" to begin cooking.
I've rarely (if ever) seen one fail without shorting.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then GE manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you're doing this yourself, G.E. will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
> Can I just replace the mag tube without also replacing the diod and capacitor?
Almost certainly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 11, 2009
  • 670 Answers
SOURCE: My microwave is making a humming noise but not
The part that you did not replace is the problem with the oven, the magnetron. It typically fails and shorts out, causing the oven to make a loud humming noise. Not worth fixing since the cost of the magnetron is typically as much as a new oven. Sorry that you spent your time an money replacing the wrong parts.
Posted on Jul 14, 2010
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
Ge spacemaker microwave jvm1640cj03 stopped heating. interior always clean. light, timer etc working.
If it stops heating and the other parts of the oven still work, the problem is with the magnetron circuit. If it makes a loud buzzing noise when you try to heat the food, then the magnetron has shorted out. The replacement cost for the magnetron is almost as much as a new oven, so it does not make sense to have it fixed. Sorry.
Apr 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Mar 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Mar 07, 2008 | Microwave Ovens
Loud and not heating
If it's less than a year old, it's still under warranty. If it's just over a year old, GE will still cover parts, but you'd have to pay for labor.
Contact them at http://www.geappliances.com/service_and_support/contact/
The most likely causes are a shorted high-voltage diode or a bad magnetron.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 13, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Mwave made loud buzzing noise then didn't heat up anymore
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron. Did it sound something like someone making a "gurgling" sound into a coffee cup? I think this has a a one-year warranty, with n five-year warranty covering the magnetron. You can find a local Amana-authorized servicer here: http://amana.com/amana/jsp/portalhttp.do?cs=0&BV_UseBVCookie=Yes&NextPage=7
Mar 03, 2007 | Amana AMV1162 Microwave Oven
Whirlpool GH8155XM Microwave Oven Logo
455 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
