Question about Indesit W 123 Front Load Washer
Drum filling up with water
When not in use overnight the machine's drum filled with water. Any idea why this is happening and how to rectify it? The machine is a dryer also and I was wondering whether it is something to do with the filter. In previous machines I've had the dryer filter had to be removed and cleaned regulalry to keep the machine working efficiently. However with this one there seems no obvious access to the filter.
  • bkro Apr 02, 2009
    The drum fills up with water when not in use. Not all the time only a few times.
    Problem Solver:
  • 6 Answers
There are 2 possible problems here. 1. If your waste pipe is connect under the sink and uses the sinks waste as a drain it could be that water from the sink (or dishwasher if also fitted) is entering the machine via the waste. This can be cured by ensuring that the washing machine waste hose is hooked up higher than the connection under the sink. 2. It could be that the washing machine inlet valve need replacing. After time, or if bits of dirt enter them they can let water seep through. This is easily identified by turning off the water supply where the hoses are connected to. If the machine fills up then you know it is entering via the waste hose - if it doesn't then you know its one of the valves. If it is a valve they are available from us at www.ransomspares.co.uk
Posted on Feb 28, 2007
Frigidaire model LTF214OES0 no water filling drum at start up
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Oct 02, 2011 | Washing Machines
Retains water (after a delay) in the drum after a wash cycle. Immediately after the wash cycle there is no water in the drum, however after several hours the drum has water in it?
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill! To find out which it is in the case of hot and cold fill turn the cold tap/faucet off overnight and see if water has come in or not. that will tell you. Also to check that it is just a physical problem and not a control board problem switch the machine off at the supply. If it still does it (from whichever supply) it is that valve which is not closing correctly ;-0
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 16, 2011 | AEG Lavamat 12710 Front Load Washer /...
Wash drum will not fill with water at all
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Aug 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My He3 begins to fill the drum with water (very slowly) after the cycle is done, I have to turn off the hose valves after the cycle to keep this from happening. Any ideas what is letting the water back...
sounds like you have a bad water valve..if water is come in try to unplug the washer if water stop you have a bad control if it keep filling you have a bad water valve
Sep 20, 2009 | Washing Machines
Tumbler Washer drum fills with water when unit is not operating.
yes the water vale is defective it has goten a little piece of sand of something in it and it dont take much replace the valve and the problem will be gone good luck
Nov 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Bosch WFX Excel
You have to replace the water inlet valve, the valve where water enters your machine.
Jan 22, 2008 | Bosch Exxcel WFX 2467 Front Load Washer
Drum filling up with water when not in use.....
only source is leaking inlet valves and only way to cure is to replace
May 14, 2007 | Tricity Bendix AW1000W Front Load Washer
Indesit W 123 Front Load Washer Logo
125 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
