Question about MSI K8N Neo4-F Motherboard
Dont know where the power wires
Ya i got this bored but i dont know where the power wires go on the thing couled you help out
  • David Cates May 11, 2010
    need to know either the manufacturer, model number, or the serial number.
  • 661 Answers
If you look at the maual it should tell you
http://www.msi.com/index.php?func=downloadfile&dno=3989&type=manual
there is a 24 pin connector located between the memory sockets and the FDD connector
there is a 4 pin connector near the edge of the board in the vicinity of the CPU socket
hope this helps
Posted on Apr 15, 2009
I have an older 1980's Olsen furnace that the blower motor won't run, I have replaced the motor and the capacitor and still nothing, I have power so only thing left is a grey box with Honeywell.
Ya probably the fan switch that you mentioned if u know how to use a multimeter get one thst way you dont buy parts u dont need if u dont know how to use one or what a multimeter is probably cheaper to call an expert
Nov 30, 2017 | Heating & Cooling
96 toyota corolla... kid was driving and it just died and she pulled off the road. Nothing happens when we turn the key. There is power on the Instrument panel but no cranking or starter sound at all. Ive...
Hi Dave honestly sounds to me like ya could have had an alternator go out on ya. I would check the actual voltage with a meeter, if it is above 12v then I would locate the starter relay in the junction box under the hood and jump the relay and see if the starter engages. another key thing to check is the small wire on the starter as these were prone to bad connection because of the slide on style connection. hope this leads ya in the right direction
Dec 05, 2013 | Cars & Trucks
I am looking for a wire harness diagram for a optiway fortress 1704fs
Hello,i dont know what that is lol.but this site i will give ya is what it says :WWW.ALLDATASHEET.COM
Type in your product & download it to an Adobe Reader + print it & save to a polythene slweeve folder for future.please rate me as in thumbs up 1 to 4 for my answer,i normally only do for the disabled,but scrolling through things,your question caught my eye.im disabled,but dont waste my life crying about it lol.whats the point.The site i give ya is free,have a nice day Colin.
Oct 07, 2010 | Health & Beauty
How to hook up my dvd player
ya its easy there are 3 wires yellow for video & red - white for audio just plug that wires in the same color socket from tv to player
Jun 12, 2010 | Hitachi DV-P745U DVD Player
GREEN LIGHT IN BACK OF TOWER COMES ON. BUT POWER TO THE TOWER AND FANS DONT CUT ON.. WHATS THE PROBLEM
The power supply generates 3 different voltages for the system. The most common cause of the symptom you are describing is a loss of the 5V supply line. This is an internal failure of the power supply that sometimes can be easily fixed, but the cost of repair is likelt to be higher than a replacement supply. A typical power supply will cost around $40. If you have another system around, swap the power supplies between the two. If the system now appears to work, you have confirmed the problem.
Dan
May 05, 2010 | HP Pavilion A730N (PJ510AA) PC Desktop
1992 bmw 325is
not the fuses but the printed circuit on the back of the speedo ??? possibly
Jul 09, 2009 | 1992 BMW 3 Series
1999 nissan pathfinder, won't turn over.
By using a prob/test light(make sure that battery is fully charged) If not sure if battery is fully charged try boosting with jumper cables. Then try cranking if not sound like a clicking is heard check power wire at the starter check the fthick one thats bolted on to starter for constant power (should have power all the time as long as battery is connected) then with ignition on and in cranking postion(attenpt to crank)check second wire for power there should be power when key is in crank position and will go out when key is released. IF YOU GET POWER WHEN IN CRANK POSITION .. then the starter is BAD. Replace and that will fix you atrating problem. If ther is NO power from constant power wire then it coul mean a loose positive batter pole or corrosion on terminals or may be a bad fusible link, these links are on the positive battery poll. check and make sure NONE of them are burnt out/broken. This problem could also mean a bad ignition switch too or blown ignition fuse please check all fuse. Good luck and thanks for using FIX YA, conatct if you need more help.
Mar 20, 2009 | 1999 Nissan Pathfinder
Smoking steering wheel
this is unfortunately a bad wiring situation located in the inside of your steering column. i would be careful. it could catch fire if not rewired soon. hope that helps ya:)
Feb 07, 2009 | 1992 Chevrolet Corsica
Z3 blowing fuses
sound like you have a dishonest dealer. i dont like to say that but somtimes its true. have you pulled the tail lights and had a look at the wiring and sockets. that would be the first place to look. if you dont find anything let me know ill digg up the wiring diagram for ya.
good luck
Aug 23, 2008 | 2001 BMW Z3
Alpine CDA-9813 CD Player problem keeping the power stay on
i have that same problem. when i turn the volume up, it shuts off but comes back on right away. the only thing i can think of is i'm not running the constant power directly from the positive terminal on the battery (which is what is recommended). not sure if thats the solution but im gonna try and wire it right anyway...
May 18, 2008 | Alpine CDA-9813 CD Player
MSI K8N Neo4-F Motherboard Logo
137 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
