Question about NexxTech N600D DVD Player
Saying do disk
The disk is spinning the model number is edp3113 they said it was working when they unpluged it
  • 905 Answers
The laser is dirty or it will need replacing
Posted on Dec 10, 2008
Whirlpool duet dryer model number gga9200lw2 says control lock how to fix problem
follow this steps and fix it. God bless you
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Oct 05, 2012 | Washing Machines
Toshiba sd-4990 dvd player will not load a disk
Your toshiba is not spinning that's why it keeps on saying loading. Unplug the dvd Open the device,once open plugin the dvd and put the dvd cleaner in the player. take your finger on the top where the dvd disk is and spin the disk. What happening is that you are cleaning the len. keep spinning until it spin on its own.Put the toshiba top back on and clean again. It should clean on it's on. Now you can play your dvd. Clean your dvd on a regular basic.
Mar 12, 2009 | Televison & Video
CD changer...doesn't play...says ''no disk''
Yes Dust can cause the problem.
If you want to try cleaning the laser optics:
1. Unplug the unit and remove the cover.
2. Locate the Cd mechanism and you should see the tray where you would normally insert the disc. Look for a glass lens about 1/4 inch in diameter ( usually a blueish tint)
3. With a cotton swab dipped in a little isopropyl alcohol (any pharmacist should have it and it is very inexpensive ) Clean the lens. You do not need a lot of alcohol and any excess will quickly evaporate.
4. Put the cover back on and give it a try
Mar 09, 2009 | Audio Players & Recorders
Whirlpool Duet makes spinning sound but drum is not spinning.
What is the model number? To get your clothes out and the door open on that model, try unplugging it for awhile and open the door (you probably have tried that already. Some models you can take off the bottom panel and reach up and there is a little ring you can pull to open the door. (most likely) you might be hearing the pump running since it always run when spinning. If you give me the model number I can let you have the test code. You could try Pressing any key (not power or stop) hold it in for 3 seconds let go 3 seconds, press 3 sec, let go 3 sec, hold 3 sec let go. It should come up all lights on. Don't worry you can't damage anything in the test mode. Watch what it says. then press that same key about every 30 seconds to advance it. It's kind of hard to explain but I'm trying my best. It should at least unlock it in the process. Good luck
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
ribbon cable issue found with this device. look inside at the white ribbon cable. The cable likes to bunch in bewtween the spinning hub and the eye assembly, after time it may even develope a rub spot that will shut you down for good. If the cable is bunched up, try pushing it back into the bottom of the device and try again.
Nov 15, 2007 | Durabrand PDV-705 Portable DVD Player
PS2 Disk won't spin
what may have happened is that the saved files for GT4 on your memory card have now become corrupt, and the disk when put in the suysstem is trying to read the data from the card, simply deleting your saved GT4 data from the memory card should allow the disk to play as normal.
Jun 11, 2007 | Sony PlayStation 2 (PS2) Console
NexxTech N600D DVD Player Logo
Top NexxTech Televison & Video Experts
Computer Repairing
Computer Repairing
Tygh Duval
Tygh Duval
Are you a NexxTech Televison and Video Expert? Answer questions, earn points and help others
