Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint Ultima extra WD72
I have a problem with the door lock. Washing is stuck inside cycle finishes, water drains out but the door wont unlock. Is there a manual release on this machine?
  • glennred Oct 11, 2008
    my power blew in the house and my wd72 door wont open now with my towels inside
  • 67 Answers
There are 3 possibilities 1 altough the water as drianed the pressure switch as not released due to blocake in the filter, or the interlock has jammed on the closed position which means it will have to forced open or the last fault could be the power board has gone.
Posted on Jun 28, 2007
How do i open my door on the washing machine it has finished the programme but wont open and washing is still in the machine
If all the water has drained away. POWER OFF. Lid has to be removed. slide arm down inside of front panel to door lock and rease it. A new door lock would be required. An engineer can do this
Oct 03, 2014 | Hotpoint Ultima WF860 Front Load Washer
No water check supply
keep on pressing the start button for 30 second it should reset
Feb 08, 2014 | Hotpoint Ultima WD72 Front Load...
E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus buttons...plus slime. Problem solved.
Dec 20, 2009 | Hotpoint Washing Machines
Door will not unlock
You will have to remove the top cover, and release the door from the inside of the washer by forcing the door lock open manually
Please rate my solution.
Thanks.
Oct 30, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima Extra door lock will not unlock at end of cycle
could be a defective door lock. these door locks have resistance within them and with the application of power, bi-metal moves and lock the doors.
test it again by using the unit and after 10 mins and the door won't un-lock , try to knock the door switch a little bit and see if it would unlock. if it does, then it is the door lock. it is getting sticky.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Sep 02, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
Aug 23, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
373 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
