Question about HP Compaq nx7010 Notebook
Turn on Laptop gets to desktop with icons then screen goes blank
I have a Compaq nx7010 Notebook...battery ok checked & lead ok. When I turn it on goes to desktop ok and then I click on my name and then click on whre I want it to go a blank black screen comes up. Hve tried to reboot it but the same thing happens.
Can you help...Thank you Irene
    Master:
  • 461 Answers
Sounds like a video driver issue. Have you updated the Display Adapter driver recently? Press F8 while booting and select Safe Mode, then navigate to Device Manger, from Control Panel-System and Uninstall the Display Adapter and reboot.
Posted on Dec 10, 2008
  • 136 Answers
By "where I want to go", do you mean going on the internet? If all you are getting is a blank screen, then you have the "about:blank" virus. Go here, print out the instructions, and read them well. Then read them again and follow them closely. At one time I had it on a desktop system and the instructions worked just fine.
HP nx7010 - Blank Screen - wont load.
This looks like it can't recognize the hard disk or it's empty - no OS. To check that it's not a hardware fault just boot from a Linux Live-CD like http://pclinuxos.com/
If the hard disk is there and with all the data apparently intact then most likely the MBR was corrupted, fix it.
Jan 13, 2010 | HP Compaq nx7010 Notebook
My hp leptop works but the screen is blank
see if the screen feels same in the bios . If it does try updating the display drivers .
Oct 19, 2009 | HP Compaq nx7010 Notebook
Nx7010 does not start.
Hello dear, probably some BIOS values changed, causing u no displays. Try this key combination immediately after startup
esc - loads bios, but not in display
F9 - (hope its F9 in ur laptop) resets BIOS
F10 - saves BIOS to default values and exits
RESTART
Or else try removing CMOS battery, its right beneath the keyboard. (Just remove 1 screw) Remove and hold for 1 minute and then reinsert and turn up laptop on. Your PC should be fine.
Jul 04, 2009 | HP Compaq nx7010 Notebook
Have compaq nx7010 can power up but screen blank and hard disc light (between power and mains power symbols) not staying on. have tried removing battery and refitting which has worked once before but now...
The HDD light is not meant to be on solid, it comes on only when the hard drive is actually working. The situation you're describing is usually just a lockup in standby.
Although you're onthe right track with the battery, To reset the power, unplug the AC cord, remove the battery and then hold the power button for 30 seconds. Now put the battery back plug it in and turn it on. It may give you an error about not being able to resume, this is normal.
If this doesn't work get back to us with more info: does it beep when it turns on, how many times, longs/shorts.
Did you try plugging and external monitor into the laptop and rotating displays to see if your backlight is out?
Ok, giver a try and let us know.
Chris
May 24, 2009 | HP Compaq nx7010 Notebook
Remov pawar on passward
press the relevant key ( F2, Delete ) or whatever it says when you first turn your laptop on to press to get into the bios and login if you need to ( ie if it prompts you ) and you should be able to disable the passwords in the bios
Apr 17, 2009 | HP Compaq nx7010 Notebook
Cannot turn on
Ok - was there lightning recently? Does the laptop spin up, but no display? Doesn't it start up at all? Did you try it with the charger plugged in? Is there a battery you can change and try it with that?
If there is no display, try toggling te fn + f4 button, or the f(key with the little screen on it looks something like: |square|)
otherwise try using an external screen? Hope this solves your problem. If the laptop doesn't power up at all, even with a new battery/while plugged in, my best bet would be motherboard damage, in which case it needs to be replaced.
Jan 03, 2009 | HP Compaq nx7010 Notebook
WONT START UP
If You know the password, type it and get to BIOS by pressing tthe F10 button. You can change the password protection mode there, or disable the password check completely, by providing blank password. ;)
May 18, 2008 | HP Compaq nx7010 Notebook
HP Compaq nx7010 Notebook Logo
164 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
