Question about Canon PC-940 Black and White Copier
Looking for actuator switch and fuses on canon pc-940 copier
Hi Apprentice,
Thank you for trying to help! :)
As I face the machine, in the right front corner is the on/off switch. In the back left corner is a box that the plug connects to.
Using either of these locations as a starting point, where would I look for the actuator switch? And where would I locate the fuse you discuss.
Thanks, Lisa
  • 76 Answers
You can locate the fuse at the back of the machine by opening the back panel,at the back you will see a big capacitor,fuse near in that place
Posted on Dec 10, 2008
  • Fernan
    Fernan Dec 10, 2008
    infront of the machine! open the machine and tilt then look inside. in the same side of toner hopper! you will see the actuator switch inside the machine at the buttom of toner hopper. the next issue is where you find the fuse. at the back of the machine you must remove the cover to see the power supply board and you will see a fuse!if still you cannot find out i will prepare a picture and attach in my next comment good luck :)
How can I slove earror EO, in my BW PC-940
You can have this Error Code resolved, I am just not sure that it would be wise. These are the facts. You have a 10 year old machine which has an EO error code which means there is a problem with the Fusing Unit. The parts required to fix the error code are anywhere from $150.00 to $250.00 depending on if you go with the whole fusing unit or just the Fixing Film Assembly which is going to contain the defective part(s). There is some dis-assembly of the machine required in order to replace the parts. If you hire someone to do this you are looking at another $100 to $200 in labor depending on who you call. So you could easily spend $250 to $450 to repair the problem. These type of small copiers are sold brand new at Office Depot and other stores now days for $100.00. They will also have a USB port so you can hook it to a PC and use it as a printer. I am in the repair business and have been for 27 years. I would not recommend that any of my customers make a repair to this machine of this magnitude. I have in fact referred 2 of them in the last 5 months to go buy the new Canon D340 instead of repairing the old one.
Good Luck to you and Thank You for using Fixya.
WheatlandServices
Dec 23, 2010 | Canon PC-940 Black and White Copier
My Canon PC 940 won't turn on. All I hear, sometimes, is a click. No life otherwise. Help!
sounds like you have a blown fuse on the inside right by the power connector.
Sep 04, 2010 | Canon PC-940 Black and White Copier
HOW TO CHANGE THE CARTRIDGE?
Use the following steps.
1. Grasp the button on the left front side of the machine to open the top half of the copier.
2. Look for the black plastic toner cartridge on the right side.
3. Grasp a small handle on the right of the cartridge and pull it out of the copier.
4. Unpackage the new toner, pull the flexible toner seal out of the handle of the new toner cartridge.
5. Slide the new toner in place of the old and close the cover.
Instructions should also be provided with the new cartridge.
Aug 09, 2010 | Canon PC-940 Black and White Copier
Canon machine message front cover is close but
there are switch behind the front door that are activated by the front cover. you may have a broken or missing actruator pin on the front door. look very carefully on the door for anything that seems to be missing. if ther is just use a piece of paper to actuate the switch. jaime
Jul 15, 2010 | Canon imageRUNNER 400S Copier
Canon pc-940 copier will not turn on
before you go that far... plug the cannon into another outlet and see if the outlet is the issue... generally when a copier wont turn on its two things... you have power problems or your fuser is blown...
Dec 22, 2009 | Office Equipment & Supplies
Where is the fuse on the canon pc-940 copier. It
Why would a fuse have any thing to do with a clicking sound? If the fuser or fixing unit was having a problem you would get a error code. Have you replaced the toner or drum cartridge any time? If so, was the noise there before? If it was not recheck the installation and if you put the old parts back in and you have no noise, it has to be the new cartridge.... Good Luck
Oct 14, 2009 | Canon PC-940 Black and White Copier
Says there is a paper jam but there isn't
if the machine goes straight into jam code once switched on, its usually a good sign a sensor has broken or it has fallen out.
canon tech
Mar 26, 2009 | Canon PC-940 Black and White Copier
My canon pc-940 copier wont turn on
there is a actuator switch near in the by pass unit,try to push that actuator or check the switch if there is a contact?if still not try to check the fuse at the back of the machine
Dec 10, 2008 | Canon PC-940 Black and White Copier
Canon PC941 Copier: Wide white bar down middle of copies
Try replaceing the cartridge the toner has run out.
Any problems please get back to me.
Thank You
Mar 25, 2008 | Canon PC-940 Black and White Copier
Close front cover message
Well here is what I can tell you.
Open the front cover. Staring you right in the face should be a bar code/number sticker. Look forward from that and there shoule be a small plastic tab, about a half inch long and less then the thickness of a popsicle stick. It is the front cover interlock switch actuator. It may be broken off.
Or look for the opening where that tab should slide into the machine the switch may be dislogded or broken.
Probably that tab has broken off not actuating the switch on that cover.
Dec 29, 2007 | Xerox Phaser 8500/DN Printer
Canon PC-940 Black and White Copier Logo
97 people viewed this question
old marine
old marine
