Question about Toshiba 42HP95 Television
Tosihba 42hp95 television w/ blinking red light
Won't turn back on
50hp95 just shut off and now blinking red. read forums and found your link. What do I look forafter I pull the back off?
Google your model and make and add "blink codes" to the end of it. The blinks are a self-diagnostic way of telling you what is wrong. After you find out what the blink code means, go from there. Most tvs do this when a pico fuse, capacitor or convergence IC has a problem.
May 14, 2011 | Toshiba 42HP95 Television
TV won't turn on. Blinking red light on front of TV.
I'm troubleshooting the same problems here. The flashing red LED indicates a fault has occurred. I found one the three fans inside not running (the smaller of the three). I plugged in the other two fans in it's socket and they do come on, but the smaller one does not. I took the fan to my bench and applied 12V and it does not run. I'll have to replace the fan and see if the tv comes on.
Al
aoraha@gmail.com
Dec 20, 2010 | Toshiba 42HP95 Television
Will not start. screen black as the red light continues to blink. must be unplugged to get the blinking red light to stop. alive but dead.
The reason your television does not come on and you only have blinking red light is because there is a problem inside the unit.
The problem mainly is either from the main panel or the power panel of the television. There is a burnt capacitor on the main panel or the power panel that is why it is not powering up.
Unplug the television for a while, about an hour or two, so the high voltage on it will dissipate, then you unscrew the screws at the back. You will have access to the main panel and the power panel, assess it and you will find a burnt capacitor, have it replaced by turning the panel to the other side and melting it off with a soldering iron and replacing it with a new one. Then couple the television back together.
Take care
Oct 14, 2010 | Toshiba 42HP95 Television
TOSHIBA MODEL #42HP95-BLINKING RED POWER LIGHT WONT STOP
Ur power inverter board is dead.
U need a new board.
Sep 07, 2009 | Toshiba 42HP95 Television
I have a tosihba 46hm95
Try replaceing the lamp
Jun 13, 2009 | Toshiba 46HM95 46" HDTV
Toshiba 42HP95 TV turned itself off, red light blinking
has overheating issue try vacuming out the top and rear of tv. fan could be dead
Jun 02, 2009 | Toshiba 42HP95 Television
Toshiba 42HP95 Plasma tv
http://www.fixya.com/support/t101749-tv_turned_itself_off_turn_back
Worked for me, was ez, and I am a huge skeptic and not very "TV technical."
Dec 23, 2008 | Toshiba 42HP95 Television
Tv turned off by it's self
Appears that power supply section or the display device is malfunctioning. The service may not be done by yourself. Please browse for the technician near you or refer to the experts in this site.
Sep 10, 2008 | Toshiba 42HP95 Television
Turned off by itself, blinking red led at front
The clicking sound is the internal protection switch that kicked in because a fault had been detected.
First ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem on dvd with no receiver box connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jun 28, 2008 | Toshiba 42HP95 Television
Televison & Video Logo
132 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
