Question about Refrigerators
The freezer and refrigerator stops working. just before it stops, it starts to make a humming noise. I pulled the back cover and cleaned the coils, they were not very dirty. If you unplug it or turn it off for 3 or 4 hours, it starts and works fine for 4 to 5 day's, then starts same thing again. My repair man told me to buy a new one, but it's only 2.5 years old. model# glrs64zewd s# la50220180 thanks William Chancey
    Habit-Forming:
  • 171 Answers
I think your heater it's the one needs replacing, when the heater does not work, you can unplug the frige for some hours and the ice will melt from the condenser in side the freezer, remove all the racks and remove the back panel the freezer the heater is at the bottom of the condenser. it's about $50.00 for it. you can replace it, it's easy enough.
Posted on Dec 10, 2008
Have a loud humming noise
You probable have ice buildup around your evaporator fan. You would need to remove the evaporator cover inside the freezer to expose the fan and see if you have ice around it.
Mar 13, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Freezer/fridge wont cool or freeze
If your refrigerator is not cooling, the problem could be as simple as a covered vent or something more complicated that requires the help of a service professional.
Is your thermostat set incorrectly? It's possible to accidentally bump the thermostat, so check it and reset, if necessary, to the proper coolness.
Check for a damaged cord or unplugged refrigerator, then check your electrical panel to make sure fuses aren't blown or the breaker has been tripped.
Is your refrigerator crammed with items or are air vents covered? Overfilling, especially near vents, can prevent cool air from flowing around items. Reduce the amount of food and drink inside your refrigerator, and be sure to leave vents clear.
Are your door gaskets damaged or worn, allowing cool air to escape? Try this test of your gaskets: Place a piece of paper or a dollar bill between the closed door and the refrigerator frame. If you can pull it out easily while the door is closed, it's time to replace the seals.
If there's ice on the evaporator cover ( typically found on the back wall of the freezer), it's a sign that the evaporator coils inside could also be covered in ice and frost, indicating a defrost problem. Try unplugging the fridge and defrosting it before calling for help.
Is the compressor (the football-sized case on the outside back of the refrigerator) making a continuous hum or other noise? A constant noise could indicate a serious problem with one or more components. This is a repair that should be left to a refrigerator service expert.
If you hear a clicking noise every few minutes, this means your condenser is trying to work but can't. To see if a dirty condenser is to blame, check the condenser coils. These are usually found on the back or the underside of the refrigerator. If they are dirty, clean them. For instructions, see How to clean refrigerator coils and fan.
If your condenser coils are clean, the problem could be the start relay, which triggers the compressor. Have a refrigerator repair pro determine if the start relay is the culprit and to replace it if necessary.
For more help identifying the causes and solutions, read Refrigerator not cooling or watch the video below. I hope this helps!
Oct 08, 2012 | Maytag Refrigerators
The refrigerator is not cooling
For more help identifying the causes and solutions, read Refrigerator not cooling.
Sep 28, 2012 | Refrigerators
Refrigerator is not cooling
Sep 27, 2012 | Refrigerators
My fridge 2578bb stopped cooling
First of all, give your refrigerator 24 hours to come to the correct temperature after plugging it back in.
For more help identifying the causes and solutions, read Refrigerator not cooling or watch the helpful video below. I hope this helps!
Sep 27, 2012 | Samsung RS2578BB Side by Side Refrigerator
The freezer is making a humming noise from the motor, I think and everything is icing up.........i cant make it stop
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 07, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
The freezer/refrigerator stopped working. All the ice was melting in the freezer. I cleaned up all the water. It sounds like it is humming and cooling; but it doesn't feel very cool in the fridge, meat...
Refrigerator
heatman101
Dec 14, 2010 | Refrigerators
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Loud humming noise as fridge is running
Hey everyone-
I recently fixed a similar problem with my freezer. I searched first and found this and a few other sites which listed this and wanted to provide input for anyone in the future.
I have a GE GSH25JSRF SS. It is about 3 years old. Several months ago I noticed when the evaporator fan in the back of the freezer turned on it would make an awful howling or whistling sound. Basically sounded like what you would hear from the window of an older house if the wind outside was blowing real strong. It was loud enough to hear on the other end of the house.
I was convinced that it HAD to be the air blowing over the venting or a gap that created that sound. But I read different solutions on the internet and decided to take a chance on simply replacing the evaporator motor and attached fan blade. That solution worked and my house is quiet again, thank god.
I ordered the parts from a supplier on the internet. Keep in mind, though, if you're not real handy it may be more than you bargain for. Might be easier to have a service guy come out.
I'm still not sure exactly what aspect of these parts caused the howling sound. It could be a bearing within the motor or perhaps the fan blade slipping due to wear. Either way, it's fixed now. Just wanted to share. Thanks.
Oct 04, 2006 | Samsung RS2630WW Side by Side Refrigerator
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
