SOURCE: how to set the timeing on 91 geo storm
The timing marks are located near the top of the crankshaft pulley on the plastic timing belt cover. There is a notch in the pulley to mark TDC (Top Dead Center)
Align the notch with the 0 mark on the plastic cover to set your base timing.
Ground the proper circuit on the ALDL connecter located under the dashboard somewhere under the steering wheel. Check the manual for the proper circuit to ground.
With the engine warm and the circuit grounded. Set the proper timing. Un-ground the circuit and you are done.
SOURCE: how to change fuel filter on a 91 geo storm gsi
the fuel filter is direclty below the brake booster mounted on the left side fender when your facing the car from front but be careful as to not twist and break the metal hoses on the fittings on the filter
SOURCE: OBD 2 location
does not have this obd 2 ,anything before 1994 does not have this ,u have a ald conector unde steering colum a code key will flash codes for repair
SOURCE: 91 geo storm gsi, car will crank over but won't
ck the timing belt open up the oil cop see if the valves are moveing crank it over if it cranks over fast its a timing belt
