Locked computer Hello. I believe I have accidentally locked my Toshiba Satellite. I've read the owner's manual, pressing Fn +F1, backspace, or moving the mouse do not work. Nothing works. I've even taken the battery out and put back in. I must have accidentally pressed the keys today when I was moving it out of the way to clean off a table. When I moved it back, it was blank, but the power is on. We do not use a password.
  • Anonymous Dec 11, 2008
    toshiba m40 -jm8 Blue lites show the battery is charged,but laptop does not initiates
  • 1,124 Answers
If you did the steps according the manual and the computer remain unlocked seem to be a malfunction. Usually the screen blank is caused by the video card, memory or inverter malfunction.
Posted on Dec 10, 2008
Lost my wi-fi on my toshiba l455
It's common that the switch that enables/disables wifi gets hit accidentally. I believe, on your model, that pressing the Function Key (Fn) and the F8 key simultaneously is the way to turn wifi on and off.
Aug 13, 2014 | Toshiba Satellite L455D-S5976 Notebook
Press f1 f2 continue
For what purpose are you pressing the F1 key. The function keys may have different uses depending on the computer. When combined with the Fn key of a laptop they may also do certain actions. You should read the manual of your laptop to find out about the function keys.
Oct 08, 2013 | Toshiba Satellite A205-S4639 Notebook
Keyboard unlock fn key lock
go to the setup BIOS , restart the computer HOLD the CTRL key+f1 or esc depend of your model and unlock fn. Otherwise read you owner manual or download from
God bless you
Jun 15, 2013 | Toshiba C855-1W9 Satellite 15.6-Inch...
My function keys doesn't work in my laptop toshiba satellite c660-a047
The function key, labeled "Fn" and located in the lower-left corner of your keyboard, is a useful feature. By pressing "Fn" along with one of the numbered function keys at the top of the keyboard (F1 through F12), you can adjust your screen brightness, enable and disable your touchpad or wireless modem, lock your computer and complete a variety of other tasks. These keys will not work if the "Fn" key is not pressed along with them. While the "Fn" key itself does not turn on and off, there are settings that can make it behave differently, or seem to be disabled.
Click "Start," then "All programs" or "Programs," then "Toshiba." Select "Utilities," then "Accessibility." Place a checkmark in the box to make sure the "Fn" key will work whether you press it simultaneously with the F1 through F12 keys or immediately before pressing those keys. Customize the other options on the screen, then click "OK." Test your "Fn" key. One of the easiest ways to do this is by pressing "Fn" and "Esc" at the same time. This toggles the sound on your computer on and off, and will show a speaker icon on your screen if it works. Press "Fn" and "Num lock" at the same time if the "Fn" key still does not work. Use the "F11" key if your laptop has no "Num Lock" key. Test the "Fn" key again, using the same method as in Step 4. Locate a licensed repair technician if the key still is not working. A hardware issue may be at fault. Hope this helps.
Jan 09, 2013 | Toshiba satellite c660
Touchpad not working
there's a key on the keyboard that has a tracpad-like picture on it,usually it's near F1-F12,if you've found it,press Fn (function) key and the key (with picture) at the same time when the computer is on,it will active and inactive the trackpad
Aug 25, 2012 | Toshiba Satellite P105-S6197 Laptop
My computer laptop model is Toshiba satellite P750. The FN key doesn't work. Nothing happen when i touch it.
The "Fn" key is a function key, it works with the top row of F1 to F12 keys.
By pressing and holding down the "Fn" key, then pressing one of the top
row "F" keys,
I'v provided a link for you to go to for the full list of "F" functions and what they
do for you as well as how to operate them on your Toshiba Laptop.
Aug 27, 2011 | Computers & Internet
I hav a satellite l505 & recently i have been unable to turn on my wi-fi. fn+f8 is not producin the required result. when i press fn the computer doesnt display the tab which it usually produces on...
Sometimes the files become corrupted and you have to re-install the drivers and any softwear that operates your wi-fi.I've had to do that with mine a couple of times.
Aug 16, 2011 | Toshiba Satellite L505-S5966 Notebook
Brand new Toshiba Satellite L750 series. Cursor is locked Keyboard is locked How do I unlock the cursor. I've tried switching off 10s then on and starting normally. No good
Hello there,
Drivers and Manual Link
Try pressing, Function key + F9..
F1= Lock Computer Mode F2= Change Power Settings F3= Change to Sleep Mode F4= Change to Hibernation F5= Switch Active Display F6= - Brightness F7= + Brightness F8= Enable/ Disable Wifi F9= Enable/ Disable Mouse cursor
About the keyboard lock? I have no idea, because most laptops have cursor lock only. Correct me if I'm wrong. Hopefully this helps.. Thank you for posting..
Jul 12, 2011 | Toshiba Computers & Internet
I need to know what the keys f1-f12 keys usage.
The uses for the function (f1-f12) keys varies based on which program you have open at the time. Different programs use them for different things.
However, your computer also has some default uses for these keys when combined with pressing the fn (function) key.
fn + f1 locks computer
fn + f2 changes our power use profile
fn + f3 puts the computer to sleep
fn + f4 puts the computer into hibernation mode
fn + f5 changes the display/output mode
fn + f6 decreases the screen brightness
fn + f7 increases the screen brightness
fn + f8 enables/disables wireless connections
fn + f9 enables/disables the touch pad
fn + f10 turns the cursor overlay on/off
fn + f11 turns the numeric overlay on/off
fn + f12 turns scroll lock on/off
May 05, 2011 | Toshiba Satellite Pro L300 Notebook
How to unlock toshiba satellite a305 s6825 laptop
My toshiba laptop audio function has been locked and I would like to unlock it via bios but cant find the correct function or description to unlock.
can you give step by step instructions
Oct 18, 2008 | Computers & Internet
Computers & Internet Logo
255 people viewed this question
David Payne
David Payne
