Question about Frigidaire FEF336BC Electric Kitchen Range
Electric stove top and oven
Fridgeadar electric stove top and oven dont turn on, service elemants dont heat up
  • rllrgrl1 Dec 14, 2008
    My range has been in use for about 2 years, and i am a baker, so it is used frequently for baking. I just baked a batch of cupcakes while making soup, turned off the oven to allow to cool, and when i tried to turn it back on, i am getting nothing at all. the coil isn't turning red, and there is no heat. on the other hand, the stovetop is working fine. thoughts?
    i am super stressed-please help!
  • 750 Answers
Welcome to fixya.
Range does not heat (lights and timer do not operate).
This would indicate the range is not receiving the required 220 volts. Check house hold breakers or fuses, open wiring between the terminal block and the components, and the power cord.
Please remember to leave a rating before you leave
Posted on Dec 10, 2008
  • 20 Answers
if neither the cooktop nor the oven works check your voltage. Is there 240 volts to the unit. Flip the breaker off and back on. If that doesn't work, with the unit unplugged, remove the cover where the stove cord is connected and check the connections
Good Luck!!!
Wires to oven heating elemement damaged
missing or worn insulation , oven seal bad, replace with new element be sure all seals and gaskets are good, should not attemp wiring repair, replace element and reseal
Aug 18, 2014 | GE Kenmore Whirlpool Stove Bake Element
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
hi thanks for the question .F3 on a Frigidaire stove means that the oven sensor is open that's the part in the oven to the left and top it looks like a pencil replace part from the back of the stove but with 1 screw holding the sensor replace BUT power off please thanks the appliance doc
Sep 29, 2008 | Frigidaire FGB24S5A Gas Single Oven
Aeg competence b 8139-4-m - oven not heating up
your heating element is probably bad. all u have to do is, make sure the oven is off, pull elem. away from it's holders on the top or bottom of the oven, then pull the elem. loose from it's sockets then, straight out of the oven. take to home depot, or lowe's, or an used appliance store. installation is reverseal.
from sid
Apr 20, 2008 | AEG B2100-4 Electric Single Oven
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
235 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
