Question about Kenmore 47783 Electric Single Oven
Oven cut off in the middle of cooking
And nothing will come on or light up now
  • JoAnn2753 Dec 13, 2008
    I have Kenmore 47833 wall oven. The oven cut off in the middle of baking also. There is power to the oven and the breaker/fuses are working. Checked manual - no reset button. Any suggestions?
    Email me, please.
  • Kenmore Master
  • 3,463 Answers
From what you say you seem to have no power to the oven, Check for blown fuse or tripped circuit breaker, check connections in plug. do you have a reset button anywhere, check your user manual.
Posted on Dec 10, 2008
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: F3 & F1 Errors & oven shuts off
Concerning the F3(Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Concerning the F1(Stuck touch pad)
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Posted on Jun 03, 2009
  • 417 Answers
SOURCE: We have recently purchased a Coopers halogen oven.
Frozen food should be defrosted before cooking in halogen ovens.
Halogen ovens use only radiant heat and will not cook the centre of frozen food.
Posted on Jan 21, 2010
Testimonial: "very helpful - what a pity Coopers didn't think to put that information in their user book!"
I have about a 14 year old Whirpool Double Oven model RBD275PDB1. The other day it was working and then in the middle of cooking something it just went off-nothing working. I checked the fuse and it was...
If there is no power at all then I would check where the house power comes into the oven.Be sure to turn off the power before looking in the conection box.Hopefully you will not have to pull out the oven to find the box.
Jun 13, 2011 | Whirlpool RBD275PD Electric Double Oven
We have recently purchased a Coopers halogen oven. I cooked a frozen fruit pie in it and the pastry looked beautiful, but when it was cut open the middle was cold and the pastry under the fruit not cooked....
Jan 21, 2010 | Ovens
Large oven burning food on top shelf when in fan assisted mode
Always cook food in the middle of the oven. Assuming this is an electric oven, there is a heating element up there that will cause burning of food, much like a broiler works.
If you must cook that high up in the oven, then cover the food your cooking with foil.
Dec 16, 2009 | Kenmore Ovens
My Belling oven isn't working at all- no power or
Be careful with one. Turn power off at the mains first then change the socket. I suspect the wires were loose in the socket and heated up and damaged the switch. If you have a continuity meter try checking between live in and out and neutral in and out on the socket
Oct 24, 2009 | Ovens
Jun 02, 2009 | GE Ovens
Smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Feb 11, 2009 | Smeg SE399X/5 Stainless Steel Electric...
The oven stops working
if your light also cuts out intermittenly sounds like a loose connection, when heated moves and loses contact, def check wiring
Mar 01, 2008 | Electrolux EOB5630 Ultrafan Electric...
Oven not cooking evenly, outside is getting brown but inside is undercooked
Sounds like the igniter is not operating at full capacity. What happens is that the oven does not light when it should. Instead, the oven is cooling down much too far so when the oven does light it has too heat more rapidly. This causes the outside to brown/burn long before it should.
Jan 24, 2008 | Whirlpool SB160PEE Gas Single Oven
Only half cooking
Theres a handy conversion table here:- http://www.hintsandthings.co.uk/kitchen/oventemp.htm Regards
Sep 26, 2007 | Frigidaire FGB24S5A Gas Single Oven
Error message
Webgenie, the code should read F3, which indicates a open oven sensor (over 2900 ohms). The sensor should ohm out at 1080 ohms at room temp. Best thing to do is replace the oven temp. sensor. Easy job..Catriver..post back.
Sep 24, 2006 | GE Profile JTP56 Electric Double Oven
Kenmore 47783 Electric Single Oven Logo
106 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
