Question about Fantom Drives 120 GB Hard Drive
MY HARD DRIVE IS NOT DOWNLOADING WHEN CONNECTED TO THE COMPUTER
I got the device 3 years ago, used it for 2 years with no problems, I let it sit for one year, now i can't get it to work all I hear when pluged in is clicks one after another, and I have alot of things stored in it, please try to help me make it work, thank you
  • smensor Dec 11, 2008
    I still didn't get helped with my problem.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 122 Answers
Clicking coming from the hard drive normally indicates that the drive has failed. Unfortunately, you will need to purchase a new hard drive, unless the warranty on your hard drive is longer than 3 years. Your data can be recovered. I know the best buy geek squad can have the hard drive sent out for data recovery, however the cost for data recovery is quite expensive.
Posted on Mar 22, 2010
Pc d'ont reconize this drive
Primary or external ???.....
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Or even get a usb 3 lead.
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Sometimes they become faulty due to overstretching age or heavy objects sitting on top of them.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
Windows 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error.
This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition.
Now I have seen cases where Malware can break the link of a Hard Drive.
So let's try a couple of steps.
Let's go back in to "Disk Management"
Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths"
Now try selecting a new Drive Letter.
This will restore the path if it has been broken.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Sep 08, 2013 | Computers & Internet
MATCHING CABLES FOR A IOMEGA LPHD-UPC
Use a USB 3 cable it will provide more usb throughput
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
Jan 24, 2013 | Iomega 500GB Prestige USB 2.0 Portable...
MY transcend 650 gb does not boot
Desktop or Laptop ?
A USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Or even get a usb 3 lead. USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Sometimes they become faulty due to overstretching age or heavy objects sitting on top of them. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. Windows 7 First, please disconnect all USB devices and then perform the following steps:
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error. This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition. Now I have seen cases where Malware can break the link of a Hard Drive. So let's try a couple of steps. Let's go back in to "Disk Management" Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths" Now try selecting a new Drive Letter. This will restore the path if it has been broken. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
Jan 24, 2013 | Transcend Computers & Internet
DRIVER FOR A BUFFALO hd-P500US DRIVE ?
Hope this helps.
Jan 24, 2013 | Computers & Internet
Smartdisk Firelite model usbflb80 is not recognized on my laptop
How do I download music from computer to sandisk 4gb flash driver. I need how to download music free and record to this device. I promised a friend and don't want to look foolish
For downloading free songs use limewire,torents etc and for sending files to the device.
1)Insert the flash drive onto your computer. 2)Right click the song. 3)Click "Send To" ->Flash drive name. 4)The transfer will commence then.
Nov 18, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Bios says no ide device found (hard frive missing?)
If the BIOS is not detecting your hard drive, then there are two possible suspects here. Could just be your hard drive or it also be your motherboard.
If you have already reseated your hard drive and memory and the symptoms are still the same, then go to the nearest local computer shop that sells HP. Have them try a known-good hard drive on your system. If it works, purchase a new hard drive. If it doesn't work, your mobo needs to be replaced.
Jan 01, 2009 | HP Compaq Presario v3000z Notebook
The hard drive is nott being recognzied
Is the hard drive spinning? Do you have it powered?
Which OS are you in? If winxp or vista, try the following:
start | run
cmd
diskpart
list disk
If your disk is listed, then it is at least recogized by the computer. If not, then it's not connected properly or has a problem.
Apr 09, 2008 | LaCie (300728U) 250 GB Hard Drive
Downloading pictures
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 10, 2008 | Canon PowerShot A430 Digital Camera
Venturer hdp3202bs mp3 player
i have the same device and the same problem, tried downloading the drivers and it didnt work but i am using winxp and the download is for win98, i get mine to work by charging it for a while then connecting it to the computer while it's still charging, sometimes it takes a few tries, they copy all the music to another device and then fire the mp3 as far away as you can or use it for rough use in the car,I know its a shame cause other they that problem its not to bad,
Dec 10, 2007 | Audio Players & Recorders
Fantom Drives 120 GB Hard Drive Logo
93 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
