192.168.1.1/ isn't working can't set up router
Website won't come up
  • May 11, 2010
    What brand and model router do you have? They don't all use 192.168.1.1 as the address.
Can't get inside to set
Posted on Mar 26, 2009
I cant save my my galaxy pocket in stand by mode by pressing the button on the right side of my cell !!! but can be brought back from standby mode by pressing the button meant for adjusting volume...
I'm also having a hard time with this phone... But have you tried checking the settings if there isn't some option for that??? My problem is with the router function that simply won't work... Got any hint????
Aug 29, 2012 | Samsung Galaxy Pocket
None blocked
I have a D-Link router as well (DIR-628) and the Website Filter does not do anything either. The firmware is faulty and D-Link won't fix it. Unfortunately, the only way to resolve this is to buy a much newer router that does not use the same firmware. Believe me, I understand your frustration.
Alternatively, you may set up a free account at OpenDNS.com where you can block specified domains for all devices that connect to the router. I use this and it works pretty well.
Jul 31, 2012 | D-Link DIR-625 (790069292637) Wireless...
Router won't power up
Check the power adapter with a multimeter. The voltage should be the same or slightly higher that the voltage stated on the adapter's label. If there isn't any or low voltage the the adapter is faulty and needs to be replaced.
Mar 06, 2012 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cant enter my router at 192.168.1.1
Check the manufacturer's website if your router isn't set up to use 192.168.1.1
For example: my former router used 192.168.2.1
Sep 16, 2011 | Computers & Internet
Was working ok then internet down and red light on router constant - have done the turn off turn on routine and reset router to no avail. have also plugged indirectly to computer - green light then comes...
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Aug 08, 2011 | Belkin N Wireless Router wireless router
I can't get this website to work. 192.168.0.253. It's supposed to be the website to configure my BL-131 Network Camera. I got the camera a couple of years ago and just now replaced my router. ...
Replacing the router will not have changed any settings in the camera. The IP address 192.168.0.253 is the factory default for the camera, unless you assigned a new one when you set the camera up.
This is a wired/wireless camera, and if you're trying to connect wirelessly you probably have a router setup issue. Like any wireless device, the camera needs to provide the right key to connect. If you haven't set up your new router's wireless security yet, or set it up with a different key than the old one, the camera won't be able to connect. If the camera's not on your network, you won't reach it and you'll have the problem you described.
The simplest thing to do is to start fresh. Reset the camera to factory defaults with its rear-panel reset button. The button is recessed and you'll need a pen or other object to press it for a couple of seconds. Connect the camera to the router using a cable, and you'll be able to reach it again on 192.168.0.253. Set up the wireless network in your router (assign network name, security key, etc.). Then go through the camera wireless setup steps so it can connect to your network and you'll be back in business.
If you need a copy, you can download the manual and find other information here from Panasonic.
May 28, 2011 | Panasonic BL-C131 Network Camera
It won't go online but the other laptops in our house is online working fine...I tried rebooting it back to factory settings and it won't reboot what could be the problem it is showing all the...
First thing you can do is a ipconfig /release /renew on the laptop that isn't connecting.
to do that, go to:
Start>All Programs>Accessories>Command Prompt.
Once thats open, type in ipconfig /release
note, there should be a space between ipconfig and /release and renew
your ip address should come up with 0.0.0.0
Now type in ipconfig /renew
remember a space between ipconfig and /renew
You should see an ip address of 192.168.XXX.XXX or 10.10.XXX.XXX something like that, depending on your network settings.
if you do, you should be able to get on the internet.
If you see an address of 169.254.XXX.XXX
Then it would be best if you powered off the Modem and the Router.
First turn off the Router, Next the Modem.
Power back on in reverse order and see if it is able to connect then.
If all that fails, You can reset the router and see if it will connect then.
You should have a reset button on the back of the router.
Remember once the router is reset, you'll have to redo the security settings.
Hope this helps!
Please Rate;)
Gary
May 25, 2011 | Compaq Presario Notebook
I don't know how to set a time limit on my router to stop kids going on line late at night
Hide the router in your bedroom!!
is one solution.If it came with an instruction book read it find out if you can set a time limit.Go to the manufacturers website download the pdf documents.
Aug 07, 2010 | Belkin Computers & Internet
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
3com 3CRWER200-75 wireless router won´t connect to certain sites
first coonect your wifi router witjh your laptop with ether net then go to this link
http://192.168.0.1
then type user :admin and password also admin or blank
then go to dhcp then enbale it with auto .
then disconnect your cable from laptop.
then go to my network places then find wireless network then simply conect your network.
thtas it.
Nov 03, 2008 | 3Com OfficeConnect Wireless Router
Computers & Internet Logo
235 people viewed this question
David Payne
David Payne
