Question about Singer Deluxe 57820 Mechanical Sewing Machine
Singer sewing machine threading question
Even though I've read the manual and seen the pictures, I still don't understand how to thread the machine properly on one of the upper thread guides. The stitch tension can't be adjusted properly and the bobbin thread is pulled through to the top of the fabric....
SOURCE: Singer CE-100 Embroidery thread bunches up underneath fabric
I had this problem and it all came down to using the wrong backing. I kep trying to use tearaway on everything but WRONG. Using the proper backing corrects most problems. Good Luck!
Posted on Dec 28, 2007
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
SOURCE: have dificulty ftting the bobbin holder in a singer 974 machine
I need an illustration of the correct installation of a bobbin case for model 7422
Posted on Jul 18, 2010
  • 1788 Answers
SOURCE: I have a singer simple
Insert a new needle, (flat side facing rear of machine), now totally rethread. Try this, with presser foot up, pull top thread, it should pull smoothly, now lower presser foot, the thread should barely move. This should seat the thread in the tension discs. If that doesn't work, call Singer at 1-800-4singer.
Posted on Dec 27, 2010
  • 1564 Answers
SOURCE: I have recently bought Singer Quantum 9940 and I
1. Make sure your needle is correct for the fabric. Go buy some good needles in several sizes. You'll need a 90 for jeans, rounded points for fine fabrics... get a few sizes. Your manual should provided you with clues to the right needle for the fabrics. (BTW... there really is no such thing as a Universal Needle... toss it.)
2. Re-read your manual and carefully follow the instructions on threading the bobbin and the upper thread...
3. Check your tension on the upper thread... it is too loose for the application. The tension on the bottom thread is handled by a spring on your bobbin case or race. If you do not have that threaded properly you'll have problems. Same with the direction the bobbin turns... have in it backwards... problems.
Barring all these things... It might be time for a qualified Singer repair person to look at it. Sadly Singer has seriously lowered it's standards in the last 20 years.
Posted on Feb 06, 2011
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
How to thread twin needle on singer
Look in your attachments for the secondary spool pin. Then you'll thread both upper threads as normal.
Jul 30, 2012 | Singer Sewing Machines
Threading the singer 7258
try sewusa.com they have some threading diagrams
Jun 07, 2012 | Singer 7258 Sewing Machine
Where do i fix the tension at? i understand there is a top and bottom but i just dont understand. The thread keeps getting bunched up. It sews good for a bit then it just bunches up and i dont know what...
why dont you visit this website and read up some of the general info on sewing machines, should help you get started.
http://sewing.about.com/od/sewingmachineindex/bb/sewingmachines.htm
Usually you should only need to adjust the top tension a little bit for different fabrics but generally it should be fine on 5. Bottom tension is set by a little screw on the bobbin case (if yours is a removable front loading type) or sometimes a little dial if fixed horizontal bobbin case design. If machine has been set up correctly from new then bottom tension should not need to be touched at all.
It sounds more like your machine is not threaded properly, causing the thread bunching up to occur. If you don't have a manual you may find a threading diagram at www.sewusa.com or www.singerco.com, the Singer website has instruction manuals for download free for many models.
It sounds like you may be a beginner sewer, in which case, I highly recommend taking a few classes to learn how to best utilise your machine and save lots of frustration too.
Jul 07, 2011 | Singer 1507
I am trying to use a singer featherweight II but I can't figure out how to thread the machine no manual
Is this a very old machine because the manual I"ve located doesn' look like the image on Fixya.
Try this link http://www.singerco.com/uploads/download/997_white-117.-kenmore-x.pdf
Singer have various model manuals downloadable, you just need to search them at their website page http://www.singerco.com/accessories/instruction-manuals/search
Trust this helps you out.
If you don't resolve the issue and this is a vintage machine, then there is some good user groups such as Vintage Singers under Yahoo where enthusiasts share info on their old machines. Good to lurk though or go through old threads first as there is often someone else who has asked similar question in the past. There may also be manuals in their files so have a dig around.
Jun 06, 2011 | Singer Featherweight II 117
I have the singer 7442 and i cannot figure out how to get the baste stitch for gathering material on a flower girls dress. I've tried everything and there's nothing in the manual, can you help with this?...
Normally to gather fabric, you select the regular straight stitch, turn the stitch length up to maximum (4 or 5 usually), and stitch two rows of stitches, one at 10mm from edge and one at 20mm from edge.
Then gather by pulling the bobbin threads (underneath ones) from each end to gather the fabric. If doing lengths of more than 1 metre, then stop, leave long thread tails, and start a fresh length of gathering threads to avoid gathering long lengths of thread which might break on you.
If your machine has a basting stitch it might look like " .___.___.___" on the dial however, I've never been that happy with machine basting for things like attaching slippery fabric to underlining, I've always done it with needle and thread to keep the two layers matching and not stretching/slipping. For example, stitching a piece of chiffon to a underlayer of satin, even pinning carefully, these two fabrics will slip under the machine foot so I'd always do it by hand.
If you have masses of fabric to gather, sometimes what is quicker is doing a large wide zig zag over a length of perle cotton (heavier than thread) at the 15mm seam, don't let the needle pierce the cotton though. Then you can gather the fabric along the perle cotton.
Sewing machine instruction manual often assumes a knowledge of sewing techniques that you may not yet have. I have the Vogue Book of Sewing on my shelf and refer to it often. Or Singer do a good range of sewing books too, its worth investing in a good reference book.
I also love www.patternreview.com, this is such an awesome website for dressmakers/sewing enthusiasts and you will find loads of helpful tips here.
Hope this helps you a little.
Apr 16, 2011 | Singer 7422
I have a singer simple 3116 sewing machine and it stitches loose upper threads. I?ve tried adjusting the tension, re threading, flipping the bobbin around, and even different fabric. But nothing seems to...
Dec 27, 2010 | Singer 3116 Simple
Singer Deluxe 57820 Mechanical Sewing Machine Logo
54 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
