Question about Oster 76076-010 Hair Trimmer
How to attach the head back on Oster Classic Clipper
Removed the head and can't figure out how to put it back on. Help!!!!
  • 22 Answers
I dont know what model you have, so I have included the master schematic link. When you goto the link posted, click on you model for the schematics.
http://www.clipperrepair.com/inventory.htm
Posted on Feb 02, 2009
Want to use plastic attachment. What blade do I need to use with theses?
Oster 76 clippers can be used with a variety of blade sizes and combs. shaveroutlet.com has many in stock. When using comb attachments, you should use one of the following size blades; 000, 0000, 1, 10, 15, 30
ShaverOutlet com Search results for oster 76
Feb 25, 2016 | Oster Classic 76 Clipper w/ Detachable...
What blade do I use with attachments?
In general, Oster 76 clipper combs are compatible with blade sizes 10, 15, 30, 00000, 0000, 000, 1. Many are available at shaveroutlet.com
Instructions oster power pro cordless clipper
go google and see if there is a workshop or user manual for the clippers
Jun 26, 2017 | Health & Beauty
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
The metal blade fell off my O classic 76 shaver, how can i put it back on? it is the metal changing part
The part that holds the blades on came loose on my Classic 76 clipper. It turns out that the two holes for the inserts are too big. I fixed the problem by removing the inserts from the clipper body (easy since that is the problem), cleaned the inserts and holes in the clipper body and super glued the inserts back into the holes. Be careful not to use too much glue! It only takes a little.
Oct 31, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
I took the blade apart and can't figure out how to put them back together. Can you help.
the oster clippers are usually mounted with spring tab to remove blade.Should be no reassembling. If there is, it should be a couple of screws that you screw in
Oct 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
The shaving blades came loose and fell off my sunbeam shaver, how do i put them back on?
Make sure the clippers are running.
Make sure the hinge (the bit you put the blade on) is open, if it is not, prize it open with a flat head screwdriver.
With the hinge open and facing you, slide the blade on the hinge with the blade number/size facing you. Snap the hinge shut.
Jan 27, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
How to put oster golden a5 two speed head on
Go to: www.clipperrepair.com and look at the diagrams. It might help you. Also, I went to Oster's website and found help there with internal parts.
Jun 07, 2008 | Oster Golden A5 2-Speed Universal Motor...
Oster classic clipper smoke after a few use not electrical smoke
How do I do maintanience on my clipper to keep them running good
Apr 07, 2008 | Oster 76076-010 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
353 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
