The screen turned up side down and every thing is in side way
  • 58 Answers
Try the following:
Just like a ctrl-alt-del except press ctrl-alt-up arrow (on some video cards and/or tablet pc's, ctrl-alt-down arrow flips it upside down. ctrl-alt-left and right arrows also rotate the screen.
Posted on Dec 10, 2008
My TI-nspire CX CAS just got a white screen with a black stripe.
Unplug the battery? I thought that the battery was built in.
Nov 13, 2014 | Texas Instruments TI-Nspire CX CAS...
Bmwx 5390
You Need to reset it basically easy way to do that is just turn off the car open your engine cover and unattached the battery for a while and put back the battery connections and check should work.
Apr 29, 2014 | Computers & Internet
Shuts down to black screen
Sounds like it is going into Sleep or Hibernation mode.
In Control panel go to Power options and see what the settings are.
Getting out of sleep mode is accomplished by pressing the power button once.
Mar 22, 2014 | Acer Aspire 5740-6025 Notebook
Psp 2000 screen rainbow colored
Replace the screen or replace the whole thing
Aug 25, 2013 | Sony PlayStation Portable (PSP) Slim...
Turned back light down on my polaroid 4GB pmp280-4 touch screen now i cant see to turn it back up
settings is in the lower right hand side of the screen, tap there.
display is in the middle of the screen on the left hand side about one(1) inch down from the top of the screen.
the slider for brightness is down one and one-forth inches down from the top of the screen, tap about 1 inch from the left hand side of the screen, remember it is 1 1/4 inches down the screen.
NCMB
Jan 22, 2011 | Audio Players & Recorders
I keep having to unplug the screen in the coffee press. Can I adjust the tamping pessure down?
Hi
Have you ever cleaned the brew head completely? There is a spot that will plug up. Screens will cake on the back side if they are not cleaned, but the holes don't plug up much.
Hi
If you make a pre-ground shot but don't put any coffee in it, and it does the same thing you have a blockage in the brew head.
If it run normally, your grind is to fine. Push the grinder lever to a larger number.
If it still dribbles, remove the brew unit (behind the door)
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the backside towards the machine (looks like an "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (becareful, there is an O-ring, spring and inside a crystal ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the crystal ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON'T use the key to install the screen, use your fingers.....
Once the screen is out look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
With the brew unit upside down over the towel insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head.
Run another pre-ground without the coffee and rinse it out. Do this once in a while to prevent this
Dec 30, 2009 | Saeco Royal Professional Espresso Machine
Line down middle of the screen-resolution is different on sides
Computer parts can sit in warehouses and be on trucks for a long period of time. Unfortunately that means things get banged around. Sometimes they don't even work when they come out of the factory. I suggest exchanging the monitor for another one. It could also be your video card. Easiest way is to exchange it and it's free to exchange.
Jul 07, 2009 | LG Computers & Internet
Upside down display
it could be a number of things. One, it could be your graphic card settings, have a look at them. Two, i forgot but therer is a shortcut to maing your screen turn upside down. Have a look at the settings and i hope you find how to fix it.
DigicalJAi
May 19, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Panasonic tx-51-gf85h rear projection
Hi mate.
The problem is usually he 2 convergence i.c.s.
Breaking down under extreme heat. My fix after replacing these
I.c.s. is to mount a computer fan on the opposite side of the heatsinks and directing a slow and moderate airflow around the i.c.s.
May 27, 2008 | Panasonic PT-51G63 51" Rear Projection...
Blue gun control
Remove the front speaker grille and also the smal;l access panel and you will see a small control box with 6 switches 3 control the focous and 3 control the screen control. The screen control will be laid out like the CRTs are Green in the center and blue and red on either side just turn the blue down very little or you will make the CRTs shut down.
May 01, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Computers & Internet Logo
83 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
