Question about Compaq Presario 5000 PC Desktop
Compaq presario 5400us jumper settings
I'm trying to rebuild an old computer for my kid, and i need to know where i can get a manual or the jumper settings for my computer
also I'm have trouble building it. when i plug the power i get a red light on the front panel and when i turn it on the fans go on but my hds and cd roms don't, could this also be the jumpers
  • Anonymous Dec 10, 2008
    i need a manual for the 5000 aswell. i need the arrangement for the jumpers as i dont have the original manual.
    President:
  • 2,692 Answers
Here is the manufactures website that will lead you to the manual.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=93284&
Posted on Dec 10, 2008
I need to acess the BIOS on my PREsario s4020WM but i need a password to do it is old and was my parents so i cannot figure it out so i jut need the options of what the password would be or how to reset it
Disconnect the power. Remove or reset the jumper near the cmos battery. Connect and turn on your computer for a minute. Turn it off. Reset the jumper to it's original setting and you're done. Put everything back together and you're good to go. Good luck!
Dec 19, 2010 | Compaq Presario S4020WM PC Desktop
Compaq presario cpu cooling fan will not start spinning unless "helped" with tip of pen to spin over.If I dont start it manually,I get No cpu fan message,and shut down.I just replaced fan,as old had broken...
If the CPU fan speed is too slow or not working at all, the computer will shut itself off automatically to prevent damage to CPU from overheating. You may end up having to throw more money at the problem and get a new fan. I went to Compaq's web site, looked up your particualr computer, found out what type of fan you needed, and I did some research. I recommend getting the fan in the following link. It's very cheap, and has good reviews. The other fans on the site all have bad reviews. Hope this helps.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835114011
Jan 12, 2010 | Compaq Presario Cooling Fan CPU Heatsink &...
Compaq presario sr1800nx won't turn on
Check the jumper settings on the DVDRW. Depending on IDE location, you need to set the jumpers accordingly. If you have the main system hard drive on the same IDE channel as the DVDRW, set the jumpers on the DVDRW to slave, if that don't work, set them to Cable Select. I'm assuming it's an IDE drive and not SATA.
Dec 30, 2009 | Compaq Presario SR1800NX Desktop PC
Power-On Password on Compaq Presario C300
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Nov 09, 2009 | Compaq Presario Notebook
Use the HDD from my old Compaq Presario as a back-up storage disc
Yes it is possible.
a) No precautions needed except the normal grounding you always do when working on computer components.
b) Yes, make sure your jumpers on BOTH drives are set - one to master and one to slave. The new drive does not have to go on the same cable as the old drive but no matter which cable you put it on make sure the jumpers are set for both devices on the cable.
Apr 12, 2009 | HP Compaq Presario SR1920NX PC Desktop
Need case removal and upgrade instructions for Compaq 5400US
Use this HP/Compaq link for your case removal & memory upgrade procedure.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03886&lc=en&dlc=en&cc=us&product=93284&rule=29389&lang=en
Cheers,
gurutim
Mar 19, 2009 | Compaq Computers & Internet
Supposed to have 20 GB of memory, only have 1.99GB
Use windows 98 to make a rescue disk (3 1/2 floppy)
use that emergency disk to repartition and format the hard drive. You can probley use fat16.
Mar 11, 2009 | Compaq Presario 5000 PC Desktop
Old compaq presario new processor
The AMD K6 II / 350 has a 100 MHz bus speed and a 3.5 multiplier. I was online with a tech at HP and even they don't know, but if they send the motherboard manual as promised and it has the info I'll post a comment. They did say it can't be done in the BIOS. I can tell you often the major manufacturers used boards where the jumper locations were soldered and didn't even have pins to change the settings, making it pretty hard to upgrade the processor.
Do you see any jumpers on the board at all? Sometimes the multiplier & clock speed info is printed right on the board in tiny white letters.
Good luck.
Jan 01, 2009 | Compaq (283983-001) Motherboard
HP Compaq Presario C5170 Desktop
Hello, i think you want reset CMOS
1. You can remove battery on mainboard turn PC on then off install battery.
If you see there slot with three pins and two of them are connected with connector remove connector turn on PC then turn off PC set connector.
Sep 07, 2008 | Compaq Presario 5000 PC Desktop
Cd rom
Is this a new CD-ROM? Usually if the BIOS cannot see the drive it's a problem with the jumper setting on the back of the drive. Try setting the jumper to cable select. Let me know if that helps.
Jun 24, 2008 | Compaq Computers & Internet
Compaq Presario 5000 PC Desktop Logo
91 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
