Question about JVC AM FM CD DET FACE CAR STEREO
Do u guys think i can install my new jvc radio into my car
I need to know if i can install my new jvc into my 2001 for explorer or if i should take it somewhere
    Problem Solver:
  • 5 Answers
No you can do it have you done it before? its just plugs you cannot get it wrong give it a go! got nothing to loose (do you have the code for your current radio as once un plugged you cannot put it back in with out the code it will not work) if the plugs dont fit together you can buy the plugs or just do what i do and cut and f****** things off and solder them strait in! stops theevs too (sorry i am a auto electrician like jobs to be done correctly.
Posted on Dec 22, 2008
I just had a new JVC radio installed by Best Buy. The FM is perfect but I get no AM stations?
I think the problem is the JVC unit itself. Go back and tell them to swap you another unit. All this is still under warranty.
Nov 15, 2017 | JVC Car Audio & Video
When i changed ignition on 2001 ford explorer I ended up having to replace steering column now it wont turn over & the anti theft light flashes & wont stop. what can be done to get car started?
At least you know the anti theft system is working. Jokes aside, I would think that the electronic security system is not recognising the new lock and steering column. You could try leaving the battery completely disconnected for at least 2 or 3 hours to see if the system resets. Reconnect the battery and then try again with the new key. You will have to put the security code back into your radio as well. If this doesn't work, it may need to go to a Dealer to reprogram your electronic system.
Apr 13, 2015 | 2001 Ford Explorer Sport
I have a jvc kd-r440 radio installed in a 2001 stratus rt. It will play fine for a bout 10 mins or so then loses sound. If you push buttons you can hear beeps through the speakers. But no music. Tried to...
You need a new radio. Amp in the radio is bad. When you first cut on the car its cool. After 10 minutes it gets too hot to operate so it cuts off.
Oct 21, 2014 | Car Audio & Video
Just installed a JVC KD-S16 radio into a 2001 kia spectra. Everytime the car is turned off the radio stations reset and so does the clock in the car. I used the wire harness. But I think it has something...
There is a constant power wire and a power wire that is actuated when you turn the car on. sounds like you may have them reversed.
You can check the pamphlet that came with your radio to see what the Jvc color code is for your hot's.
Double check them with the wire color code on the harness.
May 18, 2010 | Car Audio & Video
I am replacing the stock radio in my 2001 dodge ram with a JVC deck. The JVC deck is smaller in size. What is the best way to install the new deck so that it is tight in place and does not vibrate while...
There are retro- fit adapter plates and housings that will match your new radio head with the original opening. Either go on line or go to your local electronics store that sells auto audio equipment and ask for such an adapter for your vehicle.
Jun 21, 2009 | Kenwood KDC-MP228 CD Player
Need fuse diagram for 98 Ford Explorer Sport
If your radio does not diplay but works it is the kcd display seen many of these with this issue new radio will correct this concern no fuses for the display
Apr 27, 2009 | 1998 Ford Explorer
Changing car radios
Hi I disconnected the battery and but that on charge i removed the radio and checked all the wireing and i think what i may have found when the guy who installed it in the first place, when he was putting the radio in place with the wiring the jack plug to the remote stalk control had come detached.
thank you
denis
Jan 26, 2009 | JVC KD-G430 CD Player
Wiring my jvc kd-g331 to a 1996 vauxhall corsa
You can go to a place that installs car stereos and purchase a universal wiring harness for your car that will cost about $15 and allow you to do the wiring very easy without the need to know what every wire is for. This harness would be wired to the harness you got from JVC for your new radio and all you need to do is to match the colors of the JVC harness to the same colors of the universal harness that would then just plug right into the factory wiring harness for your car and then the other end plugs into the connector for your JVC radio. It is very easy and insures that you have all the proper wires connected to operate your radio and have full functions available for use.
If you require to know what each wire from the JVC harness is for, just ask.
I would be happy to offer you more help if you need it, just reply to this post and I will get back to you as soon as I am able.
If you found this free information to be useful a FixYa! rating would be appropiate and very much appreciated. After all, it is the only reward we get for helping people like yourself for free.
Thanks and good luck with your radio installation,
Dave
Sep 04, 2008 | JVC Car Audio & Video
DOESN'T WORK AFTER INSTALLING A NEW CAR BATTERY
did you check the fuse on the back of the radio. it should be a small maxi fuse that might be rated any where from 5 to 20 amps. most of the time it might be helpful to unplug the radio harness and re plug it after 1 minute.
May 27, 2008 | JVC Arsenal KD-AR3000 CD Player
JVC Daisy Chain
If your autochanger has an input as well as an output connector it will be possible. The iPod adapter would have to be plugged into the changer's input, and the changer's output cable would run to the KD-G421.
This manual here from JVC shows a diagram on the middle of page 1 where an i-Pod adapter (I'm assuming you have the KS-PD100) is connected daisy-chained with an XM tuner or a DLP unit. Although it doesn't explicitly say that it would work with a CD changer, I don't think it'll be a problem as long as you have an input on the changer.
Feb 22, 2008 | JVC KD-G421 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
80 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
