Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Ice maker won't stop making ice
The little bar is up but i don't think all the way. i take out the ice container and the bar stays up, but doesn't quit making ice. i am overflowing in ice and i have no shut off valve to the ice maker.
model no: 596 72254200
mfg. no: P72254000C0
  • Anonymous Jan 09, 2009
    Same problem. The ice container is full and the bar is pushed up, but it keeps making ice. If we don't remember to periodically empty the ice bucket, we end up with a flooded kitchen. We have an Amana side-by-side.
    Habit-Forming:
  • 171 Answers
It's time to replace the ice maker, it will not stop, the you can feel the small bar when it looks in to the of position.
Posted on Dec 10, 2008
LG LFX21976ST refrigerator. Started the day with a full reservoir of ice, was using it heavily to keep some workers hydrated. The last time I tried to get ice, none came. Per the label inside the doo
The ice maker's water supply line may be frozen solid. Do not worry... take out your frozen groceries and dairy products, and let your friends store them for two days while your completely defrost your refrigerator. If you don't want to wait, try to locate a schematic (parts diagram) for your fridge and take a panel access cover off to get access to the copper tube of the water supply line inside. (Warning: this can be terminal to your fridge so don't attempt this without the exact parts diagram for your make and model.) Ensure you are heating the water pipe and NOT the refrigerant line; i.e., freon, ammonia, etc... Unplug your fridge and heat up the (water supply) copper pipe with a high wattage blow dryer... if you were a pro, I would recommend a heat gun. DO NOT USE A HAND TORCH as the soldered joint connections may come loose and it will leak afterwards. (The demand you placed on the ice maker caused the compressor to run almost continually for the ice maker assembly causing the copper pipe water supply pipe to freeze... it will take time to thaw it out by just unplugging it. In the future, when you know you need volumes of ice... make a little at a time each day and store it inside a separate ice cube container.) You may also want to check the activation lever above the ice cube container (bin) to make sure it moves freely against the switch contact. If the switch contact is jammed, it won't work. Good Luck
Oct 02, 2012 | Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
We have a Samsung RS2530BBP. The ice maker works ok... water stop coming out... What do I need to do to fix the problem?
My Samsung RS 2530BBP frige Ice maker stop tp make ice.
The water tray stays verticly after pushing the reset button and the water pours in the container instead in the tray. I purchased a new ice maker but it did the same. Any idea how to fix it
Aug 12, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Ice maker has stoped making ice. The bar that cuts it off when enough ice is made moves a little while in the up position.
lifting the bar to the full up position is how you stop the ice maker from making ice. move the bar back down and ice making will resume.
Mar 08, 2009 | Whirlpool ED2FHEXN Side by Side...
Not making ice
The filter does effect somewhat the flow of the water. For some people having problems with ice dispensing it may be as simple as lifting the metal shut off bar up and down. Then check the top of the ice tray to make sure no ice is stuck up there. When you move the metal bar up and down you should see the plastic dispenser that pushes the ice out turning or rotating. Hope this helps.
Dec 10, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice maker will not stop making ice. It keeps on coming after the bar is raised. What will fix it ?
can you raise the bar and detent it it into the off position? Will it stay there? Does the unit continue to make ice even when the bar is in the off position? If it does then there is something wrong with the icemaker. Also, you may want to check that the bar is in the proper location, meaning that the bar is inserted in the head assembly and the other end is supported if that is the type you have.
Aug 31, 2008 | Hotpoint Refrigerators
Ice Maker Making Noise
I was able to solve this problem by doing the following:
1) Carefully (because there may be sharp metal blades in this area) reached into the upper left compartment of the icemaker and pressed down on ice cubes that seemed to be lodged there and were protruding slightly above the slots they should have been passing through.
2) Press down on the cubes, forcing them through the slots and into the cube container below
3) Lift the metal arm, remove and completely empty the ice cube container
4) Return the ice cube container to the freezer, making sure it is seated properly
Close the freezer and wait until the ice cube maker begins to make new ice cubes. The sound should stop in around 10-15minutes.
Nov 06, 2007 | Jenn-Air JCD2389G Side by Side...
Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
Apr 29, 2007 | GE Profile PSS26NGS Side by Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
236 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
