Question about Epson Stylus CX4600 All-In-One InkJet Printer
Epson Stylus CX4600 printer/scanner
My printer has been down for about 10 months due to no ink. I went and purchased new ink loaded it up. everything is all hoaked up okay the printer feeds paper out and works like it is writing, but there is no ink on it. The ink is not appearing on my paper. On the computer it shows the ink is half gone already and there is nothing on my paper. I don't understand where it is going. Can you suggest something? Thank you, Joanne Nadon
  • Anonymous Aug 16, 2008
    same
It sounds like the nozzles may be blocked, if it has been left for 10 months will no ink - It will have dried up. It is probably worth you running a head cleaning procedure which can be done using the Epson software. Please let us know if this helps. Thanks Daniel
Posted on Mar 13, 2007
Epson Tylus CX4600 ink light
If any ink cartridge is empty, you won't be able to print until you replace the empty cartridge. Leave any empty cartridge installed in the device until you have obtained a replacement.
The print heads will clog up in a week or two. So you also won't be able to print until you clean the print heads.
This is a utility to manage your ink. Gives an accurate count of how many ink shots are left in each cartridge. The printer told me I need a new magenta but this program says I have 13% left. It also has separate routines for cleaning the black and color (unfortunately not individual cartridges)
http://www.ssclg.com/epsone.shtml
May 18, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Can't change ink cart. EPSON STYLUS CX 4600
I may have tripped across a solution to the ink carrier that doesn't want to behave.
I turned the printer off. Then, while holding down the Ink button, I also pressed and held the On button- and kept holding them. Somewhere in documentation I read that this would kick off some process, but I didn't remember what. It didn't turn on right away, but after 4 or 5 seconds of holding the buttons down, started up, went through some motions, and lo and behold, it landed on the spot showing me my cyan cartridge was out. Pressed it again, and it went to the cartridge change position.
I had to think about it, because I was now faced with breaking open a cartridge package worth $35 that could go towards the price of a new printer, and the printer still may not work, but I went boldly forward and it seems to be working fine.
Nov 15, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Printer won't print
epson printers has a seprate printing head that holds the ink . when your inks are new & good .utilizes fixya repair directory to find a repairman to change the printing head for u .
Sep 07, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson CX4600 inks
Yes, they use the same series ink set.
May 09, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Possessed epson stylus printer #cx4600
i would suggest this http://www.supermediastore.com/cleaning-cartridge.html or a similar product from a different supplier..
Happy New Year
John
Dec 05, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus Printer CX4600
I don't know if this will work on an Epson, but it does on Cannon. The pads on the cartridges or the ink jets in the printer head may be cloged with dry ink. Get some Q-tips and rubbing alcohol (water is a poor substitute). Take out the ink cartridges and touch the pad on the bottom with a Q-tip (one for each color). If there is color the cartridge pad is OK. Take a fresh Q-tip dip it in rubbing alcohol and GENTLY rub the little holes on the bottom of the plastic box the cartridges go in. Thse are the print head jets. You should see color. You may need to clean it a couple of times if the ink has dried down into the jets. It is OK to have the Q-tip pretty wet, but not dripping.
Hope this helps
Dec 03, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Installing my printer on computer without the disc
Go to http://www.TheServiceManualShop.com and ask if they have "A CX4600 install ISO"
If they do not have the ISO you should still be able to download the driver from the Epson support web site, but they may not have the original software extra's that were on the disk. I know for instance you can no longer get Epson PrintCD via legitimate methods only by asking other people to copy it for you - which of course is naughty and we don't condone such things!!
Oct 14, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 all in one printer, scanner
Under Maintainance in the properties of the printer it gives you the option to clean the print heads. Should work
Feb 19, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
160 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
