Question about Whirlpool Kitchen Ranges
Preassure cooker Last week I purchased a Whirlpool flat top range. Can a 7 quart preassure cooker be used on this range?
    Habit-Forming:
  • 171 Answers
Yes you can use your new pressure cooker, the only thing you can not do is clean the top when is hot, or any water when is hot, it will shatter it.
Posted on Dec 10, 2008
Fuel pressure spark car wont start
code p0341 refers to cam shaft position sensor(CMP)sensor A bank1---range/performance problem===causes--insecure sensor/ rotor---air gap---wiring---CMP sensor.. I would pay attention to the sensor and the possible causes as listed because the timing of the engine is related to the position of the cam shaft. Timing is computer controlled and will not be "off" unless the CPU cannot get a definite position of the piston to set the timing
Mar 05, 2014 | Volkswagen Golf Cars & Trucks
How do I clear the computer code PO451 Can from my truck
It is a evaporative emissions code. (evap system catches stores and eventually has the engine burn fuel vapor preassure from tank) It relates specificly to the vapor preassure sensor mounted on the evap canister.
There is either a open or short in the wiring to or the sensor itself, causing inaccurate readings, and thus throwing the code. Unless youve been in an accident, it is probably the Preassure sensor.
the canister is mounted directly above the rear dif
Feb 05, 2013 | 2008 Chevrolet Silverado 1500
My preassure cooker is spewing out water off the top, i think the problem is the rubber lining of the rim
If it is coming out between the lid and the body then it is the rubber seal...if it is coming out the top vent then the pressure is too high and the vent is keeping it from blowing up... turn the heat down a bit...
heatman101
Aug 04, 2011 | Microwave Ovens
I have an Ideal 24mini with a mega flow, I have water dripping from my discharge pipe. But the preassure gage keeps rising up even if I release some preassure freom the heating system. Iv checked the...
Hello It could be a bad/defective EXPANSION tank if it(valve) leaks when the burner is running and the pressure rises at the same time .Otherwise swap the valve as they can wear out.
Sep 21, 2010 | Heating & Cooling
How to adjust pressure on cooks essentials pressure cooker
usually the grip knob on top can be turned for preassure adj..
Nov 15, 2009 | Crock Pots & Slow Cookers
Need Manual for Sikes 3 ft Cooker
no manual needed, to much preassure means the preassure regulator is shot(the round thing on the supply line). not enough flame is usually a corroded burner
Jun 17, 2009 | Sikes Cookers CK300 Grill
Can a preassure canner be used on a whirlpool flat top range?
as long is not leaking any water when in use, if water gets to the top when itop is hot it will shatter it.
Dec 10, 2008 | Kitchen Ranges
Kitchen Ranges Logo
82 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
