Question about Roper 24 in. RUD3000 Built-in Dishwasher
I have a roper dishwasher someone gave to me and it does not have anywhere to plug it in, no wires loose, and i dont see anywhere to plug anything into it.
  • 20 Answers
Hi
Look at the bottom in front. There is a small metal cover usually with one hex headed screw holding it. Remove the screw and then the cover and there should be one white and one black wire in there. Feed your power supply through the hole in the back and use a romex connector, available at your hardware store to secure your power supply and wire nut the leads inside the box, very tight. Don't forget to put the ground on the Green screw.
Posted on Dec 10, 2008
Dishwasher LD-1420T1 tripping power in the house?
Okay, this could be tricky because depending on who installed it, they might have wired into it. Check your garbage disposal and if you have anything else plugged in nearby, check that wiring too. Some installers have a nasty issue when it comes to hard wiring. They don't like doing it. So instead of hard-wiring your garbage disposal, they'll cut it in to your dishwasher. If your garbage disposal or anything else is wired to your dishwasher the load on the washer and the current the washer is using is too high. That's going to trip your breakers. You should probably contact an electrician and have them check the breaker box to make sure it's wired correctly. You may need to upgrade the breaker or have the dishwasher circuit upgraded. If it's an old house, it could be anything but first, check to see that nothing is wired into your dishwasher. You can tell if you have a few switches in the same outlet and turn them off. If your garbage disposal won't work and the DW won't either, then you have a wiring issue. That's the easiest way to start.
Apr 06, 2014 | LG LD-1420T1 Dishwasher
Orange wire
look in the wire schematics that came with the dryer or look them up online. They should tell you what that wire is for.
Apr 27, 2010 | Roper REX4634KQ Electric Dryer
Timer
I have seen a similar question before. Look up the wire schematics and see what that wire is for. The sire schematics usually come with the dryer.
Dont know how to use the router. someone gave me
Ok get the name and number of you router and Google for a user manual download that it has pictures that show you whats what. OR go to the manufacturers website and download one they are free.
Apr 01, 2010 | Computers & Internet
Missfiring will not run changed plugs changed fuel filter changed pigtail on 2002 sportage still wont run
take a plug wire off and use a pair of pliers with rubber handles to hold the wire.hold the wire next to the plug and have someone crank over the engine.(make sure none of your loose clothing is close to anything that turns.)and if you dont see a spark then it is either your timming belt or your rotor cap.
Feb 27, 2010 | 2002 Kia Sportage
No power is there a reset button?
Check your circuit breaker or fuse box.
Also, check under the sink. Some models plug in and some are wired in. The plug might have been knocked out. Also, someone may have plugged it into the disposal plug. Try turning the switch on for the disposal and see if the dishwasher comes on.
No, there is not a reset button on a diskwasher.
Are you sure you have no power to the dishwasher?
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 24, 2009 | Roper RUD3000H Dishwasher
I have a Roper dryer and it just turns off we can
first thing to do is to find out whats wrong with the cord, get to the part of the cord that goes into the machine, wires are loose. a 220volt dryer will not heat if one of the wires are loose. you need to get into machine and make sure wires are tight. this is also a safety hazzard, do not leave machine plugged in until problem is solved
Sep 02, 2009 | Roper REX4634KQ Electric Dryer
Check engine light on ...ran fine..now no spark
get someone else to look for a loose connection plug ,and check connections inside the plugs as it sounds like one of these is burnt or corroded in some way
Apr 12, 2009 | 1994 Honda Civic
Dont know how to start it
Roper is a subsidiary of whirlpool. Call this number and they should be able to help with all operating questions.
1-800-447-6737
Hope this helps,
Kermit
Aug 24, 2008 | Roper 24 in. RUD1000DB Built-in Dishwasher
Roper Refrigerator, top freezer leaking water into refrigerator
Hi I reckon you gave either an ice block in the defrost drain system or a blockage caused by loose food bits. You can clear the ice block if you keep the fridge off for 24 hours leaving both doors open. If you have a small table fan to circulate warm room air you could speed up the process.
The second type of block with food bits may need you to open the internal rear panel of the fridge and push through a stiff wire to clear the blockage.
Jul 15, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Roper 24 in. RUD3000 Built-in Dishwasher Logo
152 people viewed this question
Top Roper Dishwashers Experts
Mike
paul
paul
Adzhall
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
