Question about Grohe Plumbing
Grohe ladylux faucet loose on counter.
I installed a Ladylux faucet (33755SD0) about 3 years ago. The base has recently worked loose where it mounts to the counter. I have the fitting key that I used to tighten the base when I installed it but the spout simply snapped into place. I need to remove the spout to re-tighten the base. How do I release the spout from the base?
  • Anonymous Mar 19, 2014
    Do not know the name of model. It s a stainless pull out spray with handle on side; one piece.?
    President:
  • 2,692 Answers
Here is the manufactures web where you may request the information you desire concerning your faucet.
http://www.groheamerica.com/s/25_4060/page/modules/iframe/index.php?if_url=http://12.130.64.173/litrequest2.htm
Posted on Dec 10, 2008
I have Grohe Ladylux and the flow will arbitrarily switch from stream to spray on its own.
Mine would stick in the spray setting. I soaked the whole head in vinegar to clean it and the problem went away.
Oct 05, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Need to tighten my ladylux
Grohe has a special tool that is used for installation that comes with the faucet. You have to remove the pullout spray and remove the curved neck of the faucet by pulling out. Insert the tool in the main body and tighten from above. Most plumbers will keep this tool when installing. I don't know if Grohe still uses the same system still today, but they did in the past.
Sep 03, 2013 | Grohe Ladylux Cafe Faucet with PullOut...
When replacing the hose on a Grohe ladylux, which end needs the gasket?
Need to replace Ladylux cafe 33755 hose, can't reach water line. How can they be removed?
Oct 25, 2012 | Grohe Ladylux Cafe Faucet with PullOut...
I have a grohe ladylux that is almost 3 years old. the water pressure is low. When i unscrewed the head water flows well, but when the head is back on it rens slowly. I,ve cleaned the screen by unscrewing...
On this particular faucet you may not be able to reach the part that might be giving you issues in the spray head. However, to take the head apart, on the spray face you will turn it counter clockwise, the aerator will come out at that point and you should be able to see down into the tube to see if there are any obstructions. Also if you are using the little Grohe water filter that goes into the handle before attaching the hose, it is possible that that is clogged especially after 3 years. You should be able to remove that altogether, or contact Grohe for a replacement. If once you have removed all of these and have found no removable obstructions, then the only other thing to do is contact Grohe for a replacement spray head which I believe they are still available. Hope that helps.
Aug 18, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
May 22, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
I have a Grohe Ladylux Plux kitchen faucet that was installed 5 years ago, and it is now loose. There isn't a way to tighten from underneath and the installation directions called for using a tool to...
you can pull the faucet arm off, the part right on top of the base , if my memory serves me correct you can tighten it with a creset wrench and the neck will pop right back on after
Aug 04, 2009 | Grohe Plumbing
Loose Grohe kitchen faucet
there are mounting plates underneath the counter which fasten the faucet to the counter.This unit will need a small allen wrench if memory serves me correctly...keep in mind that all moen faucets are lifetime guranteed and alot of folks do not take advantage of this amazing warranty which makes these the most desirable faucet on the market.however the need to tighten this faucet prob isnt a warranty replacement procedure but can be determined once mounting items and faucet is inspected...good luck
Jun 28, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe ladylux plus is leaking
I believe there is a cartrige that has some washers in the unit. There may be some debris caught in there since it was a little loose. I would turn the water off and disassymble the unit and replace any obvious washers and clean everthing up. Replace it all and try it again. If it still leaks, contact Grohe for more trouble shooting. Faucets have fantastic warranties and companies usually will send replacement parts free of charge at times. Hope this helps.
Apr 06, 2009 | Grohe Model 28 206 OOO: Ladylux Plus...
Grohe Ladylux slow to turn off
Your Grohe Ladylux should be under warranty. Call the company at 630-582-7711. Their customer service was great when they replaced my quick coupling after it broke.
Good luck
Jan 14, 2009 | Grohe Plumbing
Plumbing Logo
2,570 people viewed this question
Top Grohe Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
