Question about Thermador C302U Electric Double Oven
Oven light stays on
Lower oven light stays on. How to fix it?
    Problem Solver:
  • 4 Answers
Try cleaning the door sensors
Posted on Dec 10, 2008
    Habit-Forming:
  • 172 Answers
There is a door light switch on oven side, like the one on the refrigerator,so when you open or close the door it will automatically will turn on and off that light, your oven door is not closing tight enough.the way i fix it is by twisting a towel like a roll and placing it between the door and oven at the bottom close the hinge, then close the door gently by pressing on the door on the top corners, and trying the door to close and see if it turns of the light, your hinges are bend just a bit, and you have to bend it back to the original position, that problem happens when to much weight is on that door, or if the door springs are broken, you can find that out by puling on the top door as to opening it to test the tension on it. then test the one with the problem. and see if they have the same tension. if the doors do not have the same tension that is the problem, new springs are need it.
SOURCE:
When I light my oven, it stays on full all the time. Is it the thermostate
I'd recommend buying an oven temp dial to stick in your oven to verify the actual temp. Then you can turn on the oven using a lower setting and write down the temp for the setting. Then as you slowly adjust the setting higher and higher, note each temp. If it doesn't show a consistent increase of temp for each setting, you may need it calibrated or replaced. Good luck!
Sep 18, 2014 | Ovens
Tappan gas oven won't stay hot
bad flame sensor or check gas pressure
Aug 24, 2017 | Tappan Ovens
Have JKP44GP double electric oven. Few months ago lower oven would not stay on-can set oven to bake, stays on for 1 minute then turns off. Today the upper oven is doing the same. Severe thunderstorm last...
It sounds like you are going to need a control board. You can look for a used one online part number WB27K5210. You can also send your board in to be rebuilt. Corecentrics and Fix your board are two reputable companies.
Feb 22, 2018 | GE Ovens
The lower oven light will not go off and the door seems to be slightly ajar but even if i hold the door closed and then hit the light off button, it still stays on....?
At times the door will slightly come off track.Gently lift up on your oven door and try to glide it back on evenly.
Mar 19, 2011 | Ovens
Both oven doors do not close properly. lights stay on & can't heat properly with doors not closing tight. is there an adjustment for these doors?
We have similar Jen Air double oven and with the same problem but only on the lower oven. The doors are interchangeable and the top door fits fine but the lower door will not close completely at the top. It does turn out the light but has never cooked properly. I checked with several appliance repair shops and the hinges are not adjustable, but since one door closes and our other doesn't it is not a hinge problem, just a defective design.
We let this go too long and are out of warranty so I doubt Jennair is going to do anything. I hope someone post a solution but it is clearly not problem with the henges but with the receptacle they go into.
Jan 04, 2011 | Jenn-Air WW27430P Stainless Steel Electric...
Fan and light work, oven stays cold
one of three things are possible:either you are missing part of your 240volts at input power,or a bad neutral power wire to heating element,an oven temp control,or the thermocouple that controls oven temp
Aug 22, 2009 | Ovens
Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Nov 06, 2008 | Ovens
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
Lower oven door
here is my video might help you.
Mar 02, 2008 | KitchenAid KEBC277 Electric Double Oven
GE Double Oven JKP45BA, lower oven wont heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 30, 2007 | GE JTP48 Electric Double Oven
Thermador C302U Electric Double Oven Logo
1,633 people viewed this question
Top Thermador Ovens Experts
Marvin
Marvin
Steve Allison
Steve Allison
Are you a Thermador Oven Expert? Answer questions, earn points and help others
