Question about Kenwood ProTalk UBZ-LF14 (14 Channels) 2-Way Radio
HELP ME!!! i have 2 of the UBZ-LF14 radios and one works fine but i cant see anything on the screen, and the other one can recieve but not transmit. i need help badly
2 Suggested Answers
vrc_tech
  • 109 Answers
SOURCE: I need help
This sounds like one of those situations where the radios will need to be serviced at a local kenwood dealer or depending on the value of the radios you might want to junk them. The average radio repair runs $75.00 to $90.00 just for the labor. The other option if so inclinded to do so would be too order the service manual for this radio and attempt to complete the repair yourself. I don't know your skill level at electronics. I wish I could help you more.
Patrick
Posted on Dec 11, 2008
How many miles will the Kenwood UBZ-AR14 transmit?
Two miles under perfect conditions over flat clear terrain.
Aug 06, 2014 | Kenwood FreeTalk UBZ-LH14 (14 Channels)...
My JHP 500 Tranceiver will receive but not transmit, any Idea's
It may have been PLL instead of PPL. If so, that stands for Phase-Locked Loop, and is the circuit that the transmitter needs to generate the desired frequency to transmit on. That being the case, there's no user remedy and the unit must be serviced by a qualified radio shop.
Mar 30, 2014 | ICOM Informatique IC-A23 VHF NAV/COM Air...
Flashing red light on radio where it thinks its recieving. Transmits fine but does not recieve.
Three things come to mind:
1) The radio is receiving, hence the light, but you may have a different PL code than the other radio and it is muting the transmission. Check your programming to be certain both radios are programmed alike. The red light indicates activity on your frequency.
2) Your radio may have a problem with the receive side of the radio or a bad speaker.
3) The transmitting radio may have a problem with transmit. This can be a sign of a bad battery. Swap batteries and see if the problem moves to the other radio. If so, replace the battery. (It takes more energy to transmit than to receive, so loss of transmit is common with a bad battery.)
Best regards.
Apr 15, 2013 | Motorola CP200 Two Way Radio
One radio not recieving
You need to check your interference eliminator code. It sounds like they are not set to the same code. Also, if your radio has a Qt filter, set it to zero.
Here's a link to the manual http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5300_T5400_User_Manual_E.pdf
Aug 11, 2009 | Motorola Talkabout T5400 (14 Channels)...
Need owners manual
Hello there, I think your best bet would be to contact kenwood customer support/distribution Fax (310) 537-8235 for your manual, or they will advise what path in their division to take l'm sure,
good luck --John.
Apr 24, 2009 | Kenwood PB-K1, ,UBZ-LG9,UBZ-LG11,UBZ-LF14,...
I need help
Patrick
Dec 10, 2008 | Kenwood ProTalk UBZ-LF14 (14 Channels)...
RECHARGEABLE BATTERY IS NOT HOLDING A RECHARGE
This sounds like you have a battery that has gone bad. If this is the case then it is possible that your local dealership can sell you a new battery. If they can't then try searching for the battery number on ebay or another website that sells batteries.
Patrick
Nov 20, 2008 | Kenwood ProTalk UBZ-LF14 (14 Channels)...
Cant transmit out
Not really enough info to help you, but you MUST check the SWR of your antenna system. I've seen many cases where the antenna studs were incorrectly installed, shorting the antennas to ground. Also, make sure the Dynamike control on the CB radio is turned fully clockwise.
Aug 23, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
I NEED TO UNLOCK MY KENWOOD 2 WAY RADIO, I WILL PAY
Hello Jack. To unlock your radio:
turn power off
while pressing the mode key, turn the power back on
I also left you a voice mail on your cell phone with this solution.
Dean
Rollin CBs
Jan 27, 2008 | Kenwood ProTalk UBZ-LF14 (14 Channels)...
Neither Radio Transmits or Recieves
Have you checked that both radios are in the same Channel and the same Squelch Code? are the batteries ok? any rust in the battery contacts? Some FRS radios gets a Malfuntion, and the syntom is like that, check this first
Nov 26, 2006 | BellSouth 2231TE (22 Channels) 2-Way Radio
Radio Communications Logo
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
