Question about Dryers
Dryer won't start
I have an Admiral Capacity Plus that will not start, no light, nothing. The model # is LNC7764A71. I have replaced the door switch and the timer assembly. Still nothing. There was some debate about the thermal fuse. Could that be the problem? If not, where else should I look. The dryer was running fine and then abruptly stopped without a timer sounding...since then is not working. I have checked to maker sure I have power at the wall plug.
  • nycquit Mar 14, 2009
    Dryer won't start & no light on in drum. Was working fine but stopped mid-cycle and now won't start. Help!
  • Anonymous Mar 23, 2014
    Could this be the thermal fuse or further problems with the timer, or something else?
  • 20 Answers
Thermal fuse is your most likely suspect LA 1053
Posted on Dec 10, 2008
Why do i have no heat on my dryer after cord was replaced after it caught on fire?
I would check the heating element for continuity. If you don't have a multimeter, you could buy a cheap one or borrow one maybe? I found a video on youtube in case you need to know how to do it. Good luck
Aug 06, 2014 | Admiral Dryers
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Door Switch
Wiring
MAYTAG ADMIRAL DRYER MODEL LNC7764A71 STOPPED RUNNING ABRUPTLY DURING A CYCLE AND WILL NOT START IT HAS POWER AND THE THERMAL FUSE HAS BEEN REPLACED STILL NOTHING
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 01, 2011 | Whirlpool LER5636P Electric Dryer
Admiral Dryer Model LNC7764A71 - Loud Vibration, everything else is fine
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 08, 2010 | Maytag Dryers
Won't start, keeps beeping when i push start.
The door switch has gone bad. Replace door switch and you should be good to go.
May 16, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Will not turn on
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Dryers
Admiral capacity plus stopped working mid cycle no power
When u press the knob to start the dryer is there a buzzing noise ???
If so i guess u nee to order a new moter ...
u can do it at..www.appliancepartspros.com
Jan 07, 2010 | Dryers
Dryer not starting
Luckily, these units usually have a wiring schematic on the back, if not google it. The first thing on a washer or dryer to fail is the door switch. It's easy to replace or bypass. After that the start button itself may be bad. Follow the circuit, be careful. Use a continuity meter that beeps to check stuff. You mention a light. That means the door switch controls the light and the dryer, there will be a normally open leg and a normally closed leg. Good luck.
Nov 18, 2008 | Whirlpool LER5636P Electric Dryer
Admiral Capacity Plus Dryer won't start. No light when door open. Plugged in, Circuit Breaker Reset, socket live, (tested). Internal fuse or circuit breaker?
hi yes there is a thermal fuse in the dryer at the back on the air duct a small plastic piece with 2 small blue wires check that also door switch thanks the appliance doc
Sep 22, 2008 | Dryers
Dryers Logo
626 people viewed this question
Top Dryers Experts
