Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint hss25Gfpd ww, wtf?
I have been having a time with my hotpoint fridge. During an ice storm our power got knocked out for 12 hours, plus. When the power came back on, we had ice but no water. Talked to someone about it, they said to replace the filter (it was time anyhow), and the problem would be fixed. Well, it isn't. I figure there is some type of sediment blocking the hoses, or there is some trigger that needs to be reset. Any ideas here? Thanks guys-G HAmbone
I had the same problem. The hose connecting the water supply to the door was frozen. Just completely thaw out the freezer (which may be easier said than doen if it is full of frozen food!) and that should fix the problem.
Posted on Sep 19, 2008
    President:
  • 1,462 Answers
If water comes from bottle at bottom of fridge, prob may be that the bottle is frozen
Posted on Mar 20, 2007
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
My hotpoint fridge dispenses ice, but not water. The filter has been changed. Model #HSS25GFPE WW
Set up a shop light, one of those Halogen type lights. And have it shining right on it at the highest setting. The water in the line has frozen. After about 30 minutes to an hour it should start working again. You could also use a blow dryer but I'd rather not stand in front of the fridge that long. Remember if you got kids in the house to warn them not to touch the light!
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
Refrigerator makes ice and dispenses ice, but does
could be valve, it is located underneath on back. it also could be the mother board. Check valve with ohms metter. Also make sure water resevior or water lines are not frozen inside refrig section. Also water feed line going up through door bottom hinge on freezer is not frozen. Disconnect at couplin at left bottom front and blow through line
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Hi i have a hotpoint hss25gfpj ww side by side
Very common. Most likely you need a main control board, located in the back of the fridge.
GE refrigerator repair in orange county, ca
Feb 06, 2010 | Hotpoint HSS25GFP Side by Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Is this a recall item. Hss25gfpd ww Model
No recall on this model as of this time.
Aug 28, 2009 | Refrigerators
Mildew smell coming from bottom front of refridgerator.
Carefully empty the drain pan under the fridge and empty it.
Then clean with a bleach and water solution.
Feb 22, 2009 | Hotpoint HTM17BBSSA Top Freezer...
I have a Hotpoint hss25gfpe ww fridge with ice and water in the door. The ice works, but I am unable to get water. Why can I not get any water? The serial # is tf261776 if this is needed.
Most water dispensing fridges have a tank in the fridge to keep the water cold. If the fridge temp is too low it might freeze the tank and stop the water from dispensing. Also check the water filter to make sure it is not frozen. Water filters should be replaced every 6-12 months, if it's been longer than that it might be too full of dirt to allow water past. It also might be the water inlet valve is not opening.
Jul 20, 2008 | Hotpoint Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
312 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
