Question about Philips DVDR600VR DVD Player/VCR
DVD door won't open
We have power, but the DVD door won't open and the tray won't come out.
I read on the internet to unplug and leave for 5 minutes. It worked after that!! Thanks...
Posted on Dec 10, 2008
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
Door won;t open
I have a yellow light .on the front, and the disc tray won't
open. I have a cyberhome DVD player,CH-DVD 300.
Oct 28, 2012 | Cyberhome CH-DVD 300 DVD Player
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
Disc drive won't open
CD/DVD drive?
Some have a tiny hole, right under the tray that comes out. Use a paperclip in the hole to manually open the tray.
(Some desktop computer towers have a door in front, that needs to be eased open first, then access to the actual CD/DVD drive unit can be obtained)
Regards,
joecoolvette
Jun 02, 2012 | Dell Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
My cd rom drive has power but when you try to eject the tray it won't go out...my laptop brand is HP PAVILION DV7-1135NR ENTERTAINMENT NOTEBOOK PC
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 22, 2011 | HP (198702-001) Plug-In Module DVD Drive
Power is on door tray will not open with manual or
the possible problem of it is a defective mpeg board or the belt in tray to make it open if the motor have a supply to turn the motor the problem is the belt but if it has no supply from the mpeg to the motor the defect is on the mpeg board
Nov 18, 2009 | Denon DVD-2910 DVD Player
CD/DVD door will not open
I have the same problem once in a while usually after a disk read error. If you power off the system (unplug it) it will reset and the door will open.
Jul 13, 2009 | Bose Lifestyle 18 System
Dvd player door does not open
Check to see if anythig is blocking the tray from opening. Also the tray motor or connections may be failing. I would open the case, remove and replace as many connections, one at a time, to make sure the connections were good. If the tray still does not move, then one or more than one component has failed. It could be an electronic component or the motor.
May 30, 2009 | Coby DVD-224 DVD Player
Philips DVDR600VR DVD Player/VCR Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
