Question about Averatec 3200 Notebook
Power cord "outlet"?
My laptop was dropped while plugged in to recharge...and the "spot"
where the cord is plugged in got damaged. So, when I plug in the power cord, it goes in crooked and doesn't charge...Can this be fixed??
I REALLY hope so! My laptop is practically new!!! PLEASE HELP!!!
:o/Lucinda
  • Lucinda Dec 11, 2008
    Thanks for your quick response and advice. My husband (Mechanic whiz) ended up temporarily "fixing" my laptop.
    He just stuck his magnetic screwdriver in the "jack" and straightend out something ??? now it recharges!! But, the question is how long will it work!!! I'm keeping my fingers crossed...
    :0)Lucinda aka luvgeostr8
  • 54 Answers
Unfortunatly this is physical damage and I don't think they will take it back under warranty. I have fixed these myself, but I am good with a soldering iron.
You could try a friend that is good with a soldering iron, and you trust.
Or you could take it to a laptop repair place and have them change the main system board at cost.
Posted on Dec 10, 2008
    Master:
  • 351 Answers
Dear Lucinda,
its called physical damage , well you have to contact nearest Authorised service Centre, for replace this broken part they can fix it professionally.
Be Happy Always
Regards
My KitchenAid mixer died. It’s like there is no electric going to it. I’ve checked the outlets, GFI and the circuit breaker
Try plugging something else into those outlets and see if they work, or try plugging the mixer into an outlet that you know is working. If it still doesn't work it may be the plug on the mixer or broken wire on the power cord. Examine the power cord and look for any weak spots or damage to the cord or where the wires go into the plug. Usually the wires tend to break right where they go into the plug from bending or wear and tear. If that's the case all you need to do is buy a new plug cut the old one off and install the new plug.
Jan 26, 2018 | Electric Electrical Supplies
Easynote tj74 wont turn on
Your not getting power? When you plug the laptop in does the Battery charge light come on? Are you getting power to the laptop? Do you have a multimeter to verify voltage from th AC outlet to the AC jack? Or ,the power gets to the laptop and push the on/off button you get no response? Or, you push the on/off button and the laptop starts then shut down? No lights, no leds blink. Remove battery, Try another cord/charger. Has it been dropped or damaged that would jar loose a connection, or pulled by the cord resulting in a damaged AC jack?
Nov 19, 2012 | Computers & Internet
No power when universal power cord plugged into outlet
A bit vague.Can you be more specific.
No power at AC outlet, Bad cord, damaged computer AC plug in. Does your compyter work on batteries? You did not specify if it is a Laptop or not, no specifics.
Nov 04, 2012 | Computers & Internet
Wont turn on
1.Plug the Inspiron's AC power cord into a power outlet and try to power on the laptop again. By far the most common cause of a laptop's not powering on is a dead battery.
2.Plug the AC adapter into a different outlet to check for a "dead" outlet. If you have the cable plugged into a surge protector, plug the cord into a different slot on the surge protector or "bypass" the surge protector by plugging the cable into an electrical outlet. If the Inspiron now powers on, replace the surge protector or have an electrician examine any "dead" outlets in the home.
3.Open the battery bay on the underside of the Inspiron by sliding the battery bay latch release lock upward and the battery bay latch release to the right. Once both latches are released, the battery bay should open.
4.Remove the battery.
5.Purchase a compatible replacement battery for laptop. Be aware that using an incompatible battery can cause damage to your computer. If you have any doubt as to compatibility, the best option is to purchase the replacement battery directly from your laptop's manufacturer.
6.Install the new battery by following the battery-removal procedure in reverse order. Once the new battery is installed, try again to power on the laptop. If there is still no power, seek professional repair advice.
I hope you find it very helpful.
Aug 25, 2011 | Gateway Computers & Internet
I have a dell 1720 that was working great. I went to plug in the power cord and the green light went out on the power box and nothing happened when I pushed the power switch on the computer. The power...
the charging port and or motherboard is grounding out
that is to say positive and negitive coming together
wont damage the charger
once you plug the charger out of thhe laptop and outlet then plug back to outlet the light will return
has to be look at by a technician
Jun 02, 2011 | Dell Inspiron 1720 PC Notebook
Does not recharge, after it fell off the table
your laptop battery is damage or your laptop adaptor...you can check the power cord your plugging to the outlet the testing it using a multi-tester...if your laptop adaptor is OK...proceed to your laptop which is the battery unplug it from your unit...there is a slider from the buttom or back of your unit for unplugging your battery,
Oct 09, 2009 | HP Pavilion dv4000 Notebook
Power BOX supply cord problem or hardrive problem?
Check these settings first. In a clear spot on the screen where no icons are, right click and go to properties, box opens and at top should list from R to L, themes-desktop-screensaver-appearance-advanced. click on screensaver, close to bottom click on power, another box should open, click on power schemes, make sure it's set to portable/laptop, and at bottom make sure settings for plugged in are are set to never. If it's not that then you have a bad power supply cord, or a bad power supply unit in laptop. If it's new and under warranty take it in and have replaced if not warrantied then will cost you about 100-150, just a guess!! hope this helps. But it sounds like the supply cord making the beeping noise might be bad. Make sure it's plugged all the way in as well.
Nov 17, 2008 | Toshiba Satellite M40-S417TD Notebook
Averatec 3200 Notebook Logo
54 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
