Question about NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive
Open hard drive enclosure
How do you open the Nexxtech nhde25 hard drive enclosure to remove the drive?
(I found your question because I had the same question. Decided to go for it.) The aluminum top and bottom covers are held in place by the indentations on the sides which fit into channels on the plastic chassis inside. I used a flat knife blade to gently pry by the front end of one side until the cover moved moved slightly out of the channels, then switched to the other side. Once I had it started, I was able to just lever the cover off by grasping the front corners and swinging it up in the reverse motion of the installation procedure. Caution: Prying too hard or far at once will bend the covers and or nick the plastic chassis extrusion. Good luck
Posted on Aug 11, 2010
My Nexxtech nhde35 ext. hard drive is suddenly not working. Now when I plug it in, the indicator light alternately blinks red/blue. The PC does not see the drive at all. Tried swapping to another hard...
Seems most likely that the drive enclosure has failed, since swapping to a different HD made no difference. If so enclosure will have to be repaired, or replaced.
Jan 03, 2011 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Computer recognises usb connection briefly and then drops it. computer never sees hard drive
This generally means you have a failed USB controller board or a failed drive inside the enclosure.
Try removing the hard drive from the shell and transferring it into a new external enclosure. If this works you're done, if not the fault is in the drive. I can offer you some advice on DIY methods or direct you to a professional lab near you if you provide your location.
Hope this helps FixYa,
Crankstart
Mar 23, 2010 | NexxTech Portable Hi-Speed USB 2.0 Kit...
HARD DRIVE ENCLOSURE RECOGNITION BY MY PC PROBLEM
Had the same problem today. I finally noticed that the pin bay on the enclosure was large enough to allow the pins to be offset by one pin set. The open pins were hidden by wires. Once I carefully aligned the pins, everything worked fine.
Robert
Jun 01, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
External hard drive enclosure
I too purchased a Nexxtech Hard Disk Enclosure and my Vista-based computer keeps telling me to try a USB 2.0 setup...the USB's ARE 2.0...did you try the setup disk that came with your unit?...I tried on mine but still a no go...I may have to return it to Best Buy & try somrthing different.
May 19, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Laptop VISTA basic will not recognize 3.5" Nexxtech enclosure as mass storage device
run diskmgmt.msc there it will show all disk drives. if it detects usb mass storage and the hd is not showing. soulds liek hd is bad or jumper set wrong
Apr 28, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Problem setting up Enclosure
Please check if your jamper of the hardrive must be set to primary settings. Or possible your usb connector having lost contact problem.
Hope this will be helpful to you.
Oct 26, 2007 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Nexxtech 3.5" Hard Drive Enclosure (NHDE35)
I'm not saying this will solve all problems, but it solved it for me. I am running Vista and got this to work following someone's instructions from another forum.
The slot in the enclosure that you plug the hard drive into has one set of holes fewer than the hard drive has pins. This means you can plug the hard drive in two ways "left" and "right" if you will. I had to plug my hard drive in so that the unused pins were farthest from the power cable that plugs into the hard drive.
Incidentally this made the screw holes line up better, too.
Oct 01, 2007 | NexxTech Portable Hi-Speed USB 2.0 Kit...
NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Logo
266 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
