Question about Krups Nespresso 554
Krupps 554 Nespresso machine won't turn on
It has worked great for over year and half and suddenly red light won't activate. Machine is dead. Krupps only has a few service centers and requires sending it out of state for high mail cost. Would like to fix it locally in Denver Colorado.
4 Suggested Answers
dahaka
  • 347 Answers
SOURCE: I have a Krups Nespresso
Hello endres,
Here you can find the user manaual.
http://www.krupsusa.com/NR/rdonlyres/780A0DB4-2A87-4308-954A-ED60C3B68B08/19887/867.pdf
Good luck, and remember to rate this solution
Dahaka
Posted on May 27, 2008
VtToolMan
  • 704 Answers
SOURCE: Need an instruction manual for Krupps espresso
Hello, It appears that you may have an incorrect model number for your Krups expresso machine. However, if you want to get a manual for your unit, please use the link I've provided to enter in your model number and retrieve a free copy of the instruction manual for your unit.
If you can't find the manual for your unit, please contact the customer service folks at Krups, located on the upper left hand side of the same page and speak with them directly about obtaining a manual for your machine.
http://www.krupsusa.com/krups/Consumer_service/Home/HomeManualTemplateFile.aspx?NRMODE=Published&NRNODEGUID=%7b95E7ED2C-D602-4866-843E-0D81C062EB8C%7d&NRORIGINALURL=%2fConsumer%2bServices%2fProduct%2bSupport%2fManuals%2fUse%2bIntructions%2ehtm&NRCACHEHINT=NoModifyGuest
I hope you find this Very Helpful and best regards!
Posted on Nov 10, 2009
  • 115 Answers
SOURCE: My expresso machine won't steam. Just suddenly stopped. Have tried running vinegar through system, but still won't run through steamer.
Hi, I dont know which brand machine you have, but I should be able to work out what is wrong. If your machine has a press button or turn knob steam tap, then it could be the solenoid which opens the steam flow. The solenoid itself maybe stuck or the coil maybe faulty. You just need to work back from the steam arm to work out which solenoid it is. It should make a clicking sound when activated. Commercial machine solenoids canbe disassembled and cleaned. If its a domestic machine, then just replace the solenoid. Also, some machines have a micro switch that activates the steam valve. If its faulty, then replace it.
If its a domestic machine you have, then another thing that maybe at fault, and that is the thermoblock (small boiler). If it doesn't heat up then no steam canbe made. The thermoblock has an element inside, and they can not be replaced. You have to replace the whole thermoblock. It can be easily checked with a multi meter to see if the circuit is broken. On some thermoblocks, is a thermostat or overload sensor. It is also easily checked with a meter.
So lets break it down a) solenid
b) micro switch
c) Thermoblock
d) thermostat/ thermol overload
Hope this has help you. Id be looking towards the thermoblock. Dazza
Posted on Oct 21, 2011
Nespresso attached frother just suddenly stopped will not turn on
Red light OK does the water heat. Blue light OK but no twist then change small motor
Nov 02, 2016 | Nespresso Coffee Makers & Espresso...
Cappuccino and latte macchiato buttons blinking
The unit is heating the steam - the lights should switch to contant once the right temperature is reached. Make sure to always descale the machine if the cappuccino button light turns orange.
Mar 29, 2014 | De'Longhi Nespresso Lattissima Plus...
Nespresso citiz won['t exit descaling mode
I had the same issue, and took it to the repair shop, where the guy did the same thing, just pressed both cup buttons for 3 seconds. It worked. He said the Lungo button had to be pressed a little harder, as it had some connection problem, and thats why it didnt work for me. If you have the same problem, the machine will start buzzing for about half a sec if you press the lungo button while in descaling mode.
Nov 29, 2012 | Nespresso Citiz C110
Nespresso d290 won't turn on
Unplug the machine. Hold the On/Off button when plugging back.
Jul 11, 2012 | Nespresso D290 Espresso Machine
Why do Nespresso capsules squash?
the capsule must plop in at an angle, it it's straight it will crush and not work properly
Apr 18, 2012 | Coffee Makers & Espresso Machines
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Nov 14, 2010 | Nespresso Essenza C100 Espresso...
I need operating instructions for a 2 year old Nespresso c250
For Nespresso C250, you can look up Krups 554 or 580 and I found this manual http://safemanuals.com/user-guide-instructions-owner-manual/KRUPS/NESPRESSO-PROGRAMATIC-554-_E for download. I'm pretty sure this is the one!
Aug 09, 2010 | Vacuums
The nespresso aeroccino will not turn on.
That happens to me every once in a while, but when I shift the machine on the power plate it will turn on again...I think it's something not lining up with the power plate....I don't know if this is the same, but it always seems to work with mine...I LOVE my machine, I've had it for about a year and a half and use it every morning.....
Aug 14, 2009 | Nespresso Aeroccino Automatic Milk Frother
Water leakage inside
Use less water....
Apr 29, 2009 | Krups Nespresso 554
No function when i pushe smalle or big cup
Dear,
My wive bought a new nesspresso machine.
I will keep my old machine for repair parts for my mother, she has simullar machine.
greetings
Dec 26, 2008 | Krups Nespresso 554
Krups Nespresso 554 Logo
139 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
